Question about HP Compaq Presario SR1230NX (PJ518AA) PC Desktop
Green blinking light on back but will not turn
My computer will not turn on. There is a green light blinking on the back, which I know should be on continuously. I tried unplugging it, nothing. I tried blowing all the dust out, nothing. No power,
  • 733 Answers
It may be your power supply that's faulty.
Posted on Sep 24, 2009
  • HP Master
  • 3,267 Answers
Its possible that the power supply inside the CPU is unable to provide the required DC Voltage as required by any PC. Try and exchange it a friend's SMPS of the same ratting(wattage) as yours and see if the PC works. If not, remove the RAM from their DIMM slots and clean the contact points. But if the RAM gets spoiled/damaged the MOBO should respond with continuous beeping sounds......sodeep
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
When TV is turned on the green light comes on but the TV does not. 2 seconds later the green light turns back off.
DO THE SELF CHECK THIS SET HAS AND LET ME KNOW WHAT YOU FIND:
When you turn on and green light comes on and then goes off:
On the front of the set press and hold both the Menu and Input buttons at the same time for longer than 5 seconds and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know and if this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Aug 31, 2010 | Mitsubishi WS-65311 65" Rear Projection...
Computer will not turn on. green light blinking
Try replacing the power supply, a blinking green light usually means the power supply is missing an output voltage. If you do that and you still get a blinking green light then the motherboard will need to be replaced.
May 01, 2010 | HP Media Center m1080n (PC099A#ABA) PC...
My vaio wont turn on and the green light in the back keeps blinki
The green light blinking in the back indicates that the power supply went bad and is not turning on, go ahead and get the power supply replaced. Normally that light is supposed to be fully lit and green.
Apr 28, 2010 | Sony VAIO VGC-RB53 PC Desktop
Green power supply light blinking, computer won't start.
A lot of those E-Machines used a small power supply (150 to 180 watts) and were known to have a failure rate. There is a way to check them by jumping across a two connector wires on the end that plugs into the Motherboard. Let me know if you want try this.
Apr 25, 2010 | E-Machines T5026 PC Desktop
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Computer will not power up. there is a green blinking light on the motherboard.
did you try to uplug and plug back up?
i had that problem.
it was a short(i know because i cause the short)
i had a old motherboard dell celeron 2.0ghz and i just was bored and started touching metal to metal and it started to blink so check your motherboard
May 22, 2009 | HP Pavilion a350n PC Desktop
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Green light blinking on back of my system unit but there is no power
I had this problem and i tried everything to make it work. Now all i do is put a hairdryer at the back whilst the computer is plugged in until the light stops flashing then switch on as normal. I also noticed that when the air is warm i do not have to use the hairdryer hopes this helps.
Aug 31, 2008 | Computers & Internet
HP Compaq Presario SR1230NX (PJ518AA) PC Desktop Logo
458 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
