Question about Canon PIXMA MP780 All-In-One InkJet Printer
Trying to clean my printer heads and it is saying about h values - what should they be ? On the test it is printing but when i try to copy something or receive a fax it is not printing. HELP !
    Sergeant:
  • 191 Answers
Please first time your printer cartries is chake the full, half other in have a ink but chake, second time cotton cloth is clean this heads and use the head cleaner camical use and close the window and start print.
Posted on Sep 24, 2009
When trying to print iPad says that printer is paused
Clean the print heads at least four times in a row, without doing anything else in between... don't make a test, don't restart it; just clean the heads.
What difference did that make, please?
Aug 24, 2016 | Canon PIXMA Office Equipment & Supplies
Install print head
How to remove and clean a Canon printhead - YouTube
? 1:46
www.youtube.com/watch?v=ZheZf-vdho8
Mar 24, 2013 - Uploaded by Mike Stone A Video on how to remove and clean a print head from a Canonprinter. ... an error saying, incorrect printhead installed or something like that.
Oct 24, 2015 | Canon PIXMA MX420 Wireless All-in-One...
Trying to copy and nothing printing. Ink levels are good, paper is coming out
Perform "clean print heads" in printer properties select printing preferences,service then click clean nozzles, perform twice or thrice then do the nozzle test, if print heads are recovered your will be in safe, other wise***Two print heads are in this printer each print head leads two colors, left print head leads black & yellow and other one leads cyan & magenta. You need to replace the print heads based on the color which missed.
Jan 03, 2012 | HP Officejet 6500 Wireless All-in-One...
My brother mfc-240 printer, prints fine from my computer, but this last week when I copy something from my printer, from the top of my printer, its sounds like its copying but nothing shows up, I print a...
You have I am sorry to say a blocked print head. You would have to fit a new one but only a trained engineer could do it as the head is not a separate part and its a pig of a job if you have never done one. Take a tip and take it to the tip and buy a new one. PS, part number is LK2179001
Apr 23, 2011 | Brother 6-In-1 Printer/Fax/Copy/Scanner
My CaNON ip90 PRINTER SAYS "ERROR" WHEN TRYING TO
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Mar 08, 2011 | Canon PIXMA iP90 Mobile Printer
Hi, I'm trying to print in b&w. The printer says " no cartridge" although all four of the cartridges are in. It says "open scanner cover, then reinstall ink". If I lift the cover it then says "install...
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts, tighten the cartriges onto the slots.
Sep 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
My Kodak ESP 5 fades when printing then will go blank even when I have ink
try copying something from the printer in standalone mode and check if the same issue or not.....if it is then try and do print head cleaning from the menu option and if still does not resolve call kodak tech support as it is print head issue and needs replacement..........if the copy comes out fine and faded print is only when trying to print from the computer then it could be a software issue
Jul 01, 2009 | Kodak ESP 5 Printer
Printer printing in with stripes
You can try to perform a power purge, do it by the following:
  • Enter maintenance mode. Either with starting your machine with Menu button down, or by pressing Menu, 2, 8, 6, 4 quickly. The fax/copy/scan buttons should flash/be lit.
  • Press 7, 6.
  • Press 3, the machine should now say something like "POWER_P" or "P_PURGE"
  • Press Mono/Black start, the machine should now say "cleaning".
  • When it's done, the display should say Maintenance, and you can leave this service mode by typing 9, 9.
You can now try printing a test page again, the result should hopefully be better.
Be noted however, that this purge takes ink from your cartridges, but it's more likely to solve the issue then just trying to do more "regular cleaning".
Jun 14, 2009 | Brother DCP-585cw All-in-One Wireless...
Pixma MX850
I was working on the Pixma mx850 for 3 weeks now. I have found that you need to reset the using back to factory default. On the display look for the "printer head" cleaning and alignment. Go through the steps that it gives you for printer head cleaning. Print a test page. have you tried to copy in "black/whte" and not color? that will use the large black and not the small black cartrdge. Try a couple of black circles in "paint" if your running windows XP. make a test page of your own and print it.
Apr 15, 2009 | Canon PIXMA MX850 Multifunction Printer
HP Laserjet 1150 Ghost copy
clean the heads, re calibrate...do a test page, try again.
Feb 26, 2008 | HP LaserJet 1150 Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
old marine
old marine
