Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
SOUND PROBLEM WITH PC
WHILE I M USING VOIP TELEPHONE AT THE OTHER END THEY LISTEN TO OUR VOICE AS WE ARE SINGING. LINKE....HELLLLLOOOOOOO HHHHHAAAAOOOOWWWW AAAARRRR UUUUU
ANY SOLUTION FOR THIS PROBLEM
THANKS
MOHIB
    Genius:
  • 1,027 Answers
That is echo. Check your settings to make sure the speakers are off while you talk - that is called squelch; your mike is picking up the speaker output and feeding it back with delay. Have the other end check their settings as well.Otherwise, use a headset, with your speakers off.
Posted on Sep 30, 2009
How do I turn off ECM in my Brother MFC 8220?
From the Brother website:
If you are using Voice Over Internet Protocol (VoIP), (a technology that allows you to make telephone calls using a broadband Internet connection instead of a regular (or analog) phone line, review the information listed below. If you are not using VoIP continue to Step 8.
Voice Over Internet Protocol (VoIP) is not a marketed feature of your Brother machine, however there is a compatibility setting available with this machine that may assist with sending and receiving faxes when using VoIP. Adjusting this setting lowers the baud rate (modem speed) and turns ECM (Error Correction Mode) Off. To adjust this setting follow the steps listed below:
  1. Press Menu or Menu/Set => Fax => Miscellaneous => Compatibility.
  2. Select Basic.
  3. Press OK or Menu/Set. (For touchscreen models, skip this step.)
  4. Press Stop/Exit.
Jan 07, 2011 | Brother MFC-8220 Fax
I get little sound out of the microphone spots onm my DA-X10Pro. I have a karaoke THE SINGING MACHINE. When I use my karaokee machine mic plug in the mic works fine...but any voice into the mic...
The mics on the singing machine are very low end mics and MAY not work on your other unit. The Voco has very sensitvie inputs to use with "professional" type microphones. The Singing machine mics are going to be fairly high output and likely to overload the voco inputs. Procure some professional mics like Shure, AKG, Sennheiser or others and don't forget to use a balanced to unbalanced adapter or cable on the mics.
Jan 06, 2011 | Vocopro DaX10pro
How to use olympus telephone pickup tp7
Look this instructions is the same operation Comparable Models:
  • SONY ECM-TL1 Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • Olympus TP7 Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • TC-L Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • CC-10 Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • CC-20 Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter
  • TC-W Cellular, Cordless, Analog, Digital, VoIP Telephone Record Adapter http://www.tvps.com/ecsdownloads/ECS-EBPR/ECS-EBPR-Cordless-Cellular-Telephone-Recording-Adaptor.pdf
Feb 11, 2010 | Olympus Audio Players & Recorders
How would fax run on VOIP? what requirment it needs?
typically faxing doesn't work on VOIP. i tried many times and sometimes it would go through although it said it didn't. other times it didn't work at all. VOIP has a limited bandwidth and the fax needs to send more info over the line than VOIP makes room for.
to have the best luck, stop all downloads and other network traffic while attempting to fax, so that there are no other programs or devices using the internet. the fax will have its best chance of working that way, although it probably still won't
here are some very good tips as well:
http://chris.pirillo.com/how-to-fax-over-voip-on-the-internet/
Feb 18, 2009 | Lexmark X4270 All-In-One InkJet Printer
I have an Arris modem TM502g. internet and cable TV are working fine but I have no phone service. all the LED lights are blinking except for the 2 telephone lights and they are solid green.I have tried...
Hi sorry about the chat session the other day, i was not able to see your chat message so I end the session, but to help you with your concern, since internet is already working, then the problem here is the VoIP settings on your modem (since you said it has phone ports on the modem), usually resetting the modem wont change the VoIP (Voice over IP) settings. It would be better if you ask you VoIP provider to check if the modem's VoIP settings is setup correctly. If yes, and you have internet with the modem then upgrading the firmware may help.
If you dont have a VoIP provider then you need to get one in order for the phone line to work.
If you already have one, then contact them so they can configure the VoIP settings on that modem.Get your money's worth with their service
Sep 20, 2008 | Computers & Internet
High sound when recording
Hi, I'm having problems with the telephone recording using a digital cordless phone. Once the hanset is picked and conversation is going on, the unit does not record???
May 29, 2007 | Denpa USB-24 Digital Voice Recorder
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
54 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
