Question about Canon PowerShot A470 Digital Camera
Lens errors and restart - Canon PowerShot A470 Digital Camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 19, 2010
  • 502 Answers
Try to unstick the lens by gently pushing it in or pulling it out a little bit. IF that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Posted on Jul 15, 2010
Lens error.. I have restarted & restarted camera..still same lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 20, 2010 | Canon PowerShot A420 Digital Camera
LENS ERROR, RESTART CAMERA...
CANON IXUS 561
Lens sometimes does not extend and error message 'lens error restart camera' appears when camera is turned on. This does not work without several tries and much button pressing. Problem is not caused by finger(s) in front of lens barrel.
May 20, 2010 | Canon PowerShot A560 Digital Camera
Lens error, restart camera.How can I restart the camera IXUS 60?
Since the camera is locked after lens error, you will restart camera removing batteries.
If this does not help, then you are in one of the following conditions:
Lens error and lens does not retract.
Try helping lens gently back in while you turn off the camera holding the button at same time.
Lens error and lens do not extend.
Restart the camera , and try gently tapping the camera back with the palm of your hand whilst restarting camera at same time.
If that does not help, then one part on the camera lens assembly is broken or out of place, or dirt inside lens mechanism caused the fault.
The lens must be disassembled by a technician to fix the problem.
If the problem is not fixed swapping batteries and resetting, then the camera must be taken apart and tested by a technician.
Here you can get a quote on repair: Repair
Aug 22, 2009 | Canon Cameras
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 28, 2009 | Canon Cameras
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
How do i restart my canon camera?
Restart means turn it off and on. But I believe that you failed to mention the other words that go with this error, namely "Lens Error, Restart Camera". Sadly, restarting the camera usually does not work to correct the lens error.
Oct 11, 2008 | Cameras
Lens Error, Restart
Nikon System error help????
Sep 05, 2008 | Nikon COOLPIX L12 Digital Camera
How do you fix 'lens error restart camera' I put it in my bookbag. I guess i threw my bookbag around and now i have this "lens error, restart camera." The lens froze halfway and it's staying that way....
WE WENT TO THA BEACH AND TOOK SOME PIC AND LATER THAT DAY WHEN WE WENT TO TAKE MORE PIC IT SAID LENS ERROR RESTART CAMERA BUT WE DON'T KNOW HOW TO RESTART THE CAM
Aug 18, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens Error, Restart
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Dec 31, 2007 | Cameras
Canon PowerShot A470 Digital Camera Logo
210 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
