Question about Canon CLC 1180 Copier
E020 Error in CLC 1180 Copier
How i rectify this problem? it occur every month
    Sniper:
  • 153 Answers
You have a drum/developer related error
Posted on Sep 28, 2009
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
Error e020/04e0 for clc 1180
You need to Reset Code From Function_Clear_Err_OK. Check Dens_K in Display_Dens if it is to less i.e. bellow -2.5 Check Whether Black toner is present in hopper or replace Black developer
Oct 24, 2011 | Canon CLC 1180 Copier
Pls Solve my problem : Canon CLC 1180 Copier error Switch power Off and On again. E020 0481 Mr. Santosh Kolte. Pune.
The probable causes for error :
The developer has deteriorated.
• The developing cylinder fails to
rotate.
• The developing assembly is not
locked.
• The toner concentration (patch
detection) sensor is faulty.
• The developer inside the
developing assembly is faulty.
• The toner level sensor is faulty.
• The concentration sensor is
subjected to stray light (no cover,
front cover open).
• The photosensitive drum has
deteriorated.
In error code E020-0481, means that the problem is in black developer. So I would first try to replace Bk developer, check the developer station for malfunctions ( broken gears, broken developing roller bushings,... ).
Hope that helps!
Jun 20, 2011 | Canon CLC 1180 Copier
Error codes E020/04E0 and E061/0040
Clean the thermistors and the thermofuses the first copier,to second copier vacuum cleaning the suction fan ventilator and ozone filters.
Jul 22, 2009 | Canon CLC 1180 Copier
E020-00A3
your back up data is currupt, you need to change your p-sens-p value check your door spect for all default value. after that clean your sensors that is found below the black developing assy. take machine off unplug from outlet replug turn machine on DO A GRADUATION ADJUST that should solve the problem / if not unplug the the same sensors , then repeat the first prod.
Dec 24, 2008 | Canon CLC 1180 Copier
CLC 1180 with error E020 with sub 0124
Did you change the Magenta stater/ developer? A E020 code is saying that the toner desity is low. Try replasing the developer and run the ATDC for Megenta and see if that helps. You may have a problem with the developing ass'y it self. You may be able to take another colors dev. ass'y with the hopper open and see if the code goes away. The sub code 0124 means that it is the Magenta dev. ass'y
Jan 29, 2008 | Canon CLC 1150 Color Copier
Canon CLC 1180 Copier Logo
339 people viewed this question
old marine
old marine
