Question about Dell Latitude D600 Notebook
Pushing on power button three green lights come on for one secone
Pushing power button three lights come on for one second the two outside ones go out leaving the center one blinking for five seconds then everything goes dead every once and a while all three stay on machine boots up but the screen stays in one position instead of moving along
    Novelist:
  • 137 Answers
Click here you would find the details for led codes. you may select any laptop. codes remain the same.
Posted on Sep 26, 2009
I have a separate fax line for my Canon MX310. It goes into fax mode but noting happens. I also cannot receive faxes.
The only reason to call the phone company is if you're not getting a dial tone on that line. Otherwise, have you shut down the printer and tried to reset it to factory defaults. To do that, follow the instructions below:
  • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
  • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
  • 3 Release "Stop/Reset" while holding down the "Power" button.
  • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
  • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
  • 6 Push the "Power" button, then lift the MX310 cover open.
  • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
  • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
  • Good Luck Mark
Feb 20, 2015 | Canon PIXMA MX310 All-In-One Printer
Printer does not print
Instructions
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
When I try to send a fax I get a redo message and no pages are sent...i have sent many faxes to this number....a message appeared after one page was scanned that said to prress clear and srop...i could not...
Please reset the Printer by following these steps:
Feb 27, 2011 | Canon MX310 Office All-In-One Printer
Shut down my PC, unplugged it, moved it to new location. Plugged it back in and it would not power up green light on the ASUS P4P800SE would not stay lite. Replaced power supply, green light on the mother...
Remove cmos battery and then replace it after 3 mins or so,
Try rebooting
If no luck, remove ram modules one at a time and retest
unplug all but hdd and power connector to mobo, cpu and hard drive and retest.
failing that, could be a surge of electricity has damaged your mobo
Jan 11, 2011 | ASUS P4P800SE Motherboard
Power light is dim and the 4 ethernet connection lights are bright green - even without a cable plugged in to them... removing power for more than 60 seconds and even hold ing the reset button for more...
I found this somewhere else but can't find it now - my router got hit by a power surge - i held in the reset button for 60 seconds with the power connected and it sluggishly decided to come back to life. WRT300n V1.1 - your results may vary.
Nov 07, 2010 | Linksys WRT300N Wireless Router
Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 07, 2010 | LG 42LC2D 42 in. LCD HDTV
Push power button and lold it in green light blinks one time and then nine times fast and then cuts off light try a few seconds later and green light comes on for a few seconds and off it does this three...
Hi:
You are in HV shutdown mode, Have the Horizontal output transistor replaced as well as the Horizontal output transformer. These are the most common failure for this problem, The three blinks indicates Delfection problem, and these parts are part of the main High Voltage Deflection circuits.
Dec 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Programming garage door opener
there are three buttons on the opener.hold the 2 outside ones down for 25 to 30 seconds to erase the program. once the light (if equipped)flash rate changes,let go.
then push any one of the the three buttons and hold it in. and then push your remote. when the flash rate changes,the code is now in the homelink transmitter.the slt and slt plus had that feature.
May 06, 2009 | 2002 Dodge Durango
Driver's side window does not stay up
Try this,push the switch down and roll down the window continue to hold the button for three secon ds then roll the window up and continue to hold the switch up for three seconds.Do this again and see if it fixes your problem.
Nov 28, 2008 | 2003 Lexus IS 300
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
Dell Latitude D600 Notebook Logo
295 people viewed this question
Alun Cox
