Question about Ricoh Aficio 1035 Copier
Aficio 1035 ARDF cannot pick papers most likely when they are over 4 sheets
  • 143 Answers
Clean the takeup roller and feed belt with a damp rad (water). If that doesn't help, you man need to replace the roller, belt, seperator belt and possibly the sep roller torque limiter.
Posted on Sep 25, 2009
My alficio 1035 is having a paper jam on the drum area and immediately report error SC395 this problem started after a toner hooper change. the second problem is that it is losing toner and som is falling...
SC 395 Development output abnorma.
Remove the development unit and clean the gears.If necessary change the developer.Remove the OPC imaging unit and clean the cleaning blade.
Apr 10, 2013 | Ricoh Aficio 1035 Copier
I have af 2035/45 ricoh i am facing paper jamming at exit unit. i have done replaced sensors and bicu board and check all related wiring, but couldn,t find solution.
paper jam in aficio hasnt reset . but you must check all doors .it may be one door in your machin is open .more than more right door check it
Apr 27, 2012 | Ricoh Aficio 1035 Copier
My ricoh aficio 1035 shows a paper jam and it is cleared. There is nothing in the pathway. It continues to say there is a paper jam. What can I do? I've taken it apart in the area of the jam and...
There is an actuator type sensor between 1st paper tray and reg sensor.sometimes a piece of paper gets stuck there. Open the door on right dude and shine s torch down u may c a piece there. If not go into service mode and do an smc print and identify sensor with jam and test it in input mode.
Sep 13, 2011 | Ricoh Aficio 1035 Copier
I am Engr Desmond O,i am working on Ricoh 1035 and when is picking from the ADF and it will jam on the glass but i have clean the sensor, picking roller and the glass but till jamming paper, please what...
Im not going to explain in fine detail .It sounds like you do know what is going on.But if you open the 2 side covers and the top door on the ADF wou wil be able to remove the the white plate under the white plate is a nother sensor.If you did that then replace that sensor it can be faulty.
Aug 10, 2010 | Ricoh Aficio 1035 Copier
My aficio 1035 come on and says on the screen hard disk problem.and nothing is working copy fax scanner and printer
You can remove the back of the machine and take the hard drive out.
It has failed. Not uncommon , The stapler will not work without the hard drive. You can pick one up anywhere the sell hard drives. Probably not more than a 16 gig hard drive, but it will work with out it, just leave you a small message that the hard drive isnt working.
Jul 15, 2010 | Ricoh Aficio 1035 Copier
Line on page using ARDF
Good news!! This should be an easy fix.
If the line appears only when you are using the doc feeder, and it looks like a straight line that you have drawn with a ruller, then it is on the glass. Not the large glass where the copy lays, but the narrow glass. Make a copy using the ARDF, paying close attention to it's orientation (which side is up and which is down). Then, take the copy you made and lay it next to the narrow **** glass in exactly the same direction as it went through the feeder. Wherever your line is, there is something on the glass in that spot. Take your thumb and rub with a good bit of pressure in this spot. You might not see anything, but trust me, there is something there. It might be as small and transparent as a spot of ink. A flashlight will help. You might also try using rubbing alcohol on a soft cloth to clean it. Hope some of this helps,
Chad
Oct 11, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 ARDF is not duplexing, why?
Call a technician, seems like the original is not making the second scan pass and thus displaying a mis-feed, cut also be a small piece of paper in the feeder bloacking a sensor, bad sensor or worn feed tires. www.mfpsolutions.blogpsot.com
Sep 30, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
80 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
