Question about Acer Aspire 4315 Notebook
Screen get white when unused for sometime
In this , when we are not using the Laptop and remains in standby mood, after sometime when again touch the keypad it activated but screen gets white and blank. It only works after we restart.
Also once screen went white and also the CTRL, ALT and DEL does not work.
Kindly advice
Manish Kakkar
    Guru:
  • 126 Answers
Just disable the Hard Disk Mode, Hibenation Mode and StandBy Mode at your display properties to avoid hang-ups and system crashes.
Posted on Sep 24, 2009
How to make laptop power up correctly. Instead of white screen. The lights go on and the PC makes its usual noises but only a white screen.
Wild guess with such a small amount of unused space your system has no room to "play with". Your Idle time "repair"
may indicate Hard drive issues. If you have critical data on the drive you need to backup. I would put the laptop in the freezer if you can find space, overnight. Then try to boot to "safe mode" F8 key I believe. Do Hdd error check. Worst case, you may need to reinstall operating system with potential loss of data.
May 05, 2015 | IBM ThinkPad T23 2647 Notebook
How do I fix dead ( not stuck) Pixels on my acer laptop? It appears like a smll hole in screen
You can't fix dead pixels, the transistor is faulty. This is indicated by black spots.
Stuck pixels remain a solid color other than white. This cane sometimes be fixed using software that flashes solid colors on the screen. Hot pixels remain solid white. this can be fixed in the same manner.
http://udpix.free.fr/
http://www.jscreenfix.com/
These are free software to fix stuck pixels.
Aug 12, 2014 | Acer Aspire Computers & Internet
Ipod froze
A white screen on an iPod Touch is the sign of a generic error, meaning you won't get a specific error message. Usually when this happens the white screen won't change and the iPod is frozen on that screen. Apple Support outlines a specific series of steps to take to deal with this problem, from turning the iPod Touch off to completely reinstalling the operating system if necessary.
What the White Screen Means The white screen is a sign that a software error has occurred in the iPod Touch. Unless you received an error message first, it's usually something near the root level of the iPod's operating system that caused the iPod to cease functioning normally. Rather than shut off completely, it goes to this white screen to let you know there's been an error. Unfortunately you usually lose unsaved information when this occurs. b> Resetting b> Try turning the iPod Touch off, then on again. This is the simplest way to reset your iPod Touch. If it remains stuck on the white screen, force a reset by holding down the Sleep button (top right corner) for about 10 seconds. The screen will go dark, then the Apple logo will appear. If it turns off and doesn't turn on again, the battery may be too low. b> Restore b> If a manual reset doesn't work and the screen remains stuck on a white screen, you'll need to restore the iPod to reinstall its operating system. Plug your iPod, via its charger cable, into your computer. Open iTunes and click on your iPod, then the "Restore" button on the main screen. b> Problematic Apps b> If you consistently receive a white screen while using a particular app, the app may be faulty or installed incorrectly. Try re-syncing the app to your iPod Touch and see if that solves the problem. Otherwise, you may need to delete the app to avoid the white screen problem.
b>
Jan 27, 2013 | Apple iPod touch
Samsung laptop screen shows garbage r540
if it's something that occurs with movement, and you had you screen previously replaced i would suspect that the screen cable clip is loose, try re-seating the cable in the back of screen and securing it with some tape to ensure that that it remains clipped in place, i think that this us most likely the issue.
As for the ATI driver i sometimes see that occuring, try updating the drivers.
Oct 15, 2012 | Samsung R540 Laptop
Can't unlock the screen
Hi, when a phone remains locked, it means that the touch screen (touch pad)of the phone you are using is bad will need to be replaced.
Replace the touch pad and you will start usingthe phone again.
Take care.
Jun 09, 2010 | HTC Touch HD Smartphone
Powers up but black screen
For that you need to refix RAM memory.
It is in back side of laptop.
check in back side you find 1 plate upon battery open it then refix RAM memory.
if still same issue then you have to reset bios settings for that open back cover of laptop then find motherbord pull CMOS cell from motherbord for 10 minutes so all settings goes to factory defaults.
Then check.
Let me know if you need more assistance.
Thanks.
Oct 04, 2009 | Acer Aspire One PC Notebook
I'm also experiencing same sort of white screen problem.
To determine if the LCD screen or the video card is faulty, connect an external monitor to the video connector on the laptop. Power up the external monitor first and then the laptop. The video should divert automatically to the external monitor and if you get a normal image then the video card is OK and the fault could be the LCD screen or the video cable. Reseating the video cable and connector on the motherboard could fix yout problem.
Jun 14, 2009 | Acer Aspire 4315 Notebook
White screen
hi thanks for using fixya!
I suggest that you shoud bring your laptop to a service center to check exactly the errors are. This is the best option for now.
Best Regards!
Apr 19, 2009 | Acer Aspire 4315 Notebook
Sony vaio on Standby with black screen
Take the battery out, unplug it and then remove and reseat the ramstick(s) that fixed the problem for me, and several others that I read about online. Goodluck!
Jun 26, 2008 | Sony VAIO PCG-K23 Notebook
Laptop screen turn blank
Are you using the nVidia GeForce GO 6150 video card? If this is the case, and I'm pretty sure it is, the NV driver is not being recognized and the system is starting in VESA.
On the nVida, HSYNC/VSYNC frequencies need to be specified, after that the MIXIMUM resolution of 1280x800 should work for you.
Mar 30, 2008 | HP Compaq Presario v3000z Notebook
Acer Aspire 4315 Notebook Logo
192 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
