Question about Samsung Digimax S630 Digital Camera
Samsung s630 Wel It wont work with the memory card but with out it, it does they're 2 brand new and should word together. San disk sd card 2gb. When I put it in the camera turns on ok gets the lens out and then nothing happens the screan stays dark and no butons works. To get it working again I get the card out and the it works but not enough 9 pictures I want to be able to take more. What should I do ? please answer quick I'd like to used it soon ! Thank's Chela
    Scholar:
  • 39 Answers
About the memory cards to be used with this camera, those could be:
- MMC / SD card (Up to 2GB Guaranteed)
- SDHC card (Up to 4GB Guaranteed)
Some cards are not compatible according to the memory card
manufacturer and memory card type.
If that is the case, i'll be advising you to try 1 GB so it will work.
But if it still does the same thing with the 1 GB card or with whatever cards you're using, you could still take more pictures even without a memory card. It's just that you need to adjust the picture size and quality to the lowest resolution to have more pictures taken.
To change the size:
Rotate the mode dial to PROGRAM:
- Press +/- button (2nd button)
- Go down to where you're see 6M, 5M, ... 1M
- Select 1M for the lowest size
- Press MENU/OK to save changes
To change the quality:
- Go down to where you're see Dots corresponding to NORMAL, FINE and SUPER FINE
- Select NORMAL for the lowest quality
To turn off camera after the settings
have been changed to refresh the camera.
If it still does not work, you need to contact the Manufacturer.
I hope this help you a lot.
Posted on Jan 13, 2008
What kind of memory card do I use
You may use any SD card up to 2GB in size (4GB if you can find any). Make sure you get an SD card and not an SDHC card, as the latter are electronically incompatible and will not work. The brand and speed won't make much difference, though a faster card may download faster to your computer if you use a compatible card reader. I'd also stick with the major brands, such as SanDisk, PNY, and Lexar.
Mar 01, 2013 | Polaroid T831 Digital Camera
Will a 4gb sd memory card work on a s630?
Yes and no. According to the manual the S630 will work with SD cards up to 2GB in size and with 4GB SDHC cards. If the cards at the store are actually SDHC cards (most likely since 4GB SD cards are very rare) then they should work fine.
Jul 21, 2012 | Samsung Digimax S630 Digital Camera
I have a samsung digimax s630 and it works fine with a 32mb sd card but when i try a 2gb standard sd card camera says card locked when its switch is in the unlock position have tried two cards with the...
Check with Samsung Support if this doesn't work, I went through the entire site, at least 6 people ask the question but 0 answers, is the message next to every single one of them:
Try formatting the disk Inside The Camera, first.....
You can Chat Live Here
Mar 20, 2011 | Samsung Digimax S630 Digital Camera
Memory card error
did you already formated your memort stick? try to remove your memory card from your camcorder and insert it again. look for the settings on your camcorder. it might cause the problem. hope that helps!
CHARCOIS
Aug 17, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Error message on san disk sd card
You may have answered your own question. There is a good chance that your memory card has reached the end of its life. You might try reformatting the card with the computer and then do the format in the camera. This has worked for me before.
Jul 18, 2008 | Cameras
Memory card
connect the card in memory card reader and got to mycomputer-->right click-->manage-->disk management. see weather you memory size is correct or not if its different right click the memory card and delete the partation then create a new partation
i was done this to my san disk memory card
Feb 24, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Micro SD Not Reading
I have same problem with A1200 not recognize micro sd card.
some one help ,Please.
Thank - you.
Oct 07, 2007 | Motorola Mobility A1200
Samsung Digimax S630 Digital Camera Logo
78 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
