Question about Sharp Aquos LC-45GD4U 45 in. LCD HDTV
The blue power light is on, but nothing works on the tv. No screen power, no display, none of the buttons and the remote does not work anything on the tv either.
  • ccovello1 Sep 24, 2009
    Already tried having it unplugged for days. When I plug it back in it still only shows the blue indicator light on. Nothing works, no power or functionality to anything else on the tv. No display, none of the buttons work anything and the remote control can not turn it on or off or have any affect at all when buttons are pressed. Just that little blue light stays on. The on and off button does nothing. Only unplugging it will get the little blue light to go out.
    Sep 24, 2009 - Already tried having it unplugged for days. When I plug it back in it still only shows the blue indicator light on. Nothing works, no power or functionality to anything else on the tv. No display, none of the buttons work anything and the remote control can not turn it on or off or have any affect at all when buttons are pressed. Just that little blue light stays on. The on and off button does nothing. Only unplugging it will get the little blue light to go out.
    (will you be responding now)
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This might have happened due to loose connections or cold solder joints on the AV Board(X-sus board). Bang on the upper side of the TV with your hand and see whether it is staying on for a long time or staying on and off. If the issue is slightly resolved but not completely, then it means that a wire, connection or cold solder joint is loose which you can check after opening the back cover of the TV. If it doesn't work then try to reset your TV by switching it off and unplugging it from the mains power supply for 8-10 hours.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 24, 2009
  • Rylee Smith
    Rylee Smith Sep 24, 2009
    Hi
    Its due to loose connections inside the TV. It maybe due to faulty X-sus board connections or a faulty power supply. To be sure what is causing the problem you can check if the fans are working when you switch the TV on. If not then it is a faulty power supply. You can check all these things in the morning and then revert.
    Please do revert for further assistance.
    Thanks
    Rylee
My Nexus NX32031 won't power on. None of the caps are bulging. .
Probably power supply failure, even with no evidence of bulging caps.
Aug 13, 2014 | Nexus NX32031 LCD TV
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
May 28, 2013 | Televison & Video
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
My son bought an AOC LCD TV (model L24H898) last month and connected his laptop and XBOX to it. Yesterday we lost internet connection and the screen on the TV went blank. Now none of the button on the TV...
According to the manufacturer, to reset the entire unit do the following:
1. Press and hold "Menu" and "Channel +" on the TV. 2. Using other hand, press the power button. 3. A small screen should appear in the top left part of the screen. 4. Using the remote, select "Memory Recall" and select. 5. Power off and re-boot the computer 6. Run channel auto-scan to regain the picture.
Aug 28, 2009 | AOC L24H898 24 in. LCD TV
There is a lock on my screen and nothing works
Try holding the display button for 10 seconds, worked for mine, unless the vcr presents a different issue
Nov 10, 2008 | Insignia IS 20" TV040919 TV
Locked tv
I'm having the same problem. My screen is blue with a red lock in the bottom left hand corner. None of the buttons work except the on/off button on the television.
Sep 14, 2008 | Haier HTF20R21 20" TV
Locked tv
MY TV IS LOCKED CANNOT GET IT TO TURN ON HELP!!!!!
May 03, 2008 | Apex Digital AT1314DV 13 in. TV/DVD Combo
Locked tv
What is the make and model number of your flat screen tv.
Mar 11, 2008 | Televison & Video
Blue screen with lock
If you push and hold down the display button the lock on the blue sceen will come off.
Jan 26, 2007 | Jensen TS2050J 20" TV
Picture problems
Try pressing the disply button and hold for three to 4 seconds. This is a quick way of locking all functions also .. Once the set is working press display and hold to relock it or to unlock it. Good Luck PS please dont forget to rate this thread.
Oct 23, 2006 | Jensen TS2050J 20" TV
Sharp Aquos LC-45GD4U 45 in. LCD HDTV Logo
74 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
