Question about Philips 27PT9015D 27" TV
Top 3 inches of screen have horizontally flipped
The top three inches or so of the screen have flipped horizontally onto itself. I quick search of the web shows that this TV has been a disaster, but if I can fix it on my own, I'll do it.
Can anyone walk me through the fix on this? I haven't been able to find a solution that I can understand.
Thanks
  • kuopust
    kuopust Feb 05, 2013
    ing things last????
  • kuopust
    these tvs are junk and so is everything ive ever owned with the brand phillips,,, i'll never buy phillips products again. plus the garbage is made in mexico!!!! make it in America and make the product right and last some time,, plus give some jobs back to America!!!!
Buy a better brand!!!!
Posted on Feb 05, 2013
  • 525 Answers
That Good , you are a n electronics technician , check capacitors and resistors in vertical circuits ,
Posted on Sep 24, 2009
I have a Philips TV model: 27pt9015d. at the top of the screen several horizontal lines have appeared. it looks like the top inch is being cut off and then flipped back. that is - when credits are...
sounds like the vertical adjustment has spanned beyond the screen, causing it to jump up and then upside down. after the cover is removed look for vertical adjustment and with a non-conductive screwdriver, adjust it a little bit either way to see if it fixes it, if it doesn't fix it, then look again for the right one.
Jun 18, 2008 | Philips Televison & Video
Tip
Add Horizontal Lines in Word 2007 Document Quickly
You can add horizontal lines in Word 2007 document quickly without having to use the ribbon on the top of the page. A very easy way to add horizontal lines in Word 2007 quickly is by using the keyboard shortcuts. This method will save your time. You will be able to insert lines of many different designs by using the keyboard and not having to use the mouse at all. In order to add horizontal lines in Word 2007 document quickly, you can use one of the following procedures:
1. If you want to add a simple straight line, type three dashes (---) and press Enter on the keyboard.
2. For this style of a horizontal line, type three asterisks (***) and press Enter.
3. Type three underscores ( ___ ) and press Enter to get this line:
_____________________________________________________________
4. Type three equal signs (===) and hit Enter to get this line.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
on Jun 29, 2010 | Microsoft Word for PC
Samsung tv model un50eh5000v Having horizontal blurring and repetitive images from 8 inches from the top to the bottom of the screen. Top is clear. All inputs and stations.
It sounds like you have a defective panel. It will be cheaper for you to replace the set. Hopefully the place that you purchased the boards from have a good return policy.
May 11, 2016 | Samsung Televison & Video
Panasonic viera black line split screen horizontal 3/4 left 1/4 right
Visit the site named 'Electro-help' for more details. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 08, 2012 | Televison & Video
I have a KF-42E200A Sony Bravia LCD tv. Recently we had to replace the lamp. Since then a horizontal line appeared at the top of the screen and it has grown to about 3 inches now. The picture itself is...
The lenses in the TV are more than likely misaligned due to heat from lamp. The heat can cause the lenses to move and the red shaded horizontal line appears over time because the lenses fall out of alignment.
You just need to have the lenses realigned and the red shading will go away.
Jan 07, 2010 | Sony Televison & Video
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
3 inches of the top of the screen looks like its flipped over onto the picture
If this is a standard set, the problem is a bad capacitor in teh vertical circuit. If you can post the make and model of the set, I'll list the circuit designation and part.
Dan
Aug 14, 2008 | Televison & Video
White Horizontal Lines near the top of my Screen
this symptom is what we called vertical fold-over. vertical fold-over is characterised by a white horizontal bar on the bottom or top of the raster due to the concentration or compression of the trace lines. it an image is present, the bottom or top portion is fold over. this is caused by a vertical deflection current with poor linearity, which compresses the trace lines at the bottom or top of the screen. this symptom is is caused by a defective sawtooth wave genetator circuit, or improper biasing or defective feedback circuit of the vertical drive or vertical output transistor/ic. the negative feedback circuit in vertical deflection circuit compensates for the linearity of the trace portion of the sawtooth wave. a decrease in the capacitance of the sawtooth generator capacitor is usually the trouble. but if you do not understand anything what i have written here, better bring it to a qualified tv technician for your own safety also. good luck!
Mar 01, 2007 | JVC TM-2703SU 27" TV
Philips 27PT9015D 27" TV Logo
159 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
