The Report from Tech 1, which we were advised to obtain (costing $80)shows that my Panasonic TX-23LX50A acquired in May 2006 requires a power unit. Their quote to repair is: Parts charge $185 + Labour charge $250 = $435. As this was a $2,000 television and has been our 2nd TV and only used very spasmodically I am wondering if this particular TV model is one which has shown a history of problems. Surely, under statutory warranty you should expect such an expensive item to be fit for use for a much longer period. Hoping you can shed some light on our problem. Lorna Fleuren Phone: 4225 3331
  • 333 Answers
Any tv is made and expected to last. However there are certain conditions that shorten the life of any electronic. If the power supply has gone out it could have been caused by a power surge, or lightning in which case would be covered under your homeowners policy. (if you have it) The part you need can be bought and installed by anyone with some mechanical experience. There are 5 screws that hold the power supply on. Make sure it's not plugged in when you're doing it.
If you want to replace it yourself you get find the part here: http://spares.bigwarehouse.com.au/index.php?cPath=137_535_22759
Posted on Sep 24, 2009
Replace screen broken
You might have to spend almost 80% of the total cost of a new TV, including the price of its display panel + services.
http://google.com/+GopakumarGopalan
Dec 28, 2013 | Panasonic TX-32LE7PA 32 in. LCD TV
Vertical Flashing Lines on Toshiba 42HP84 Plasma 42"
this is most likely the whole power board, I would replace it fully or replace faulty component(s)
Oct 24, 2008 | Toshiba 42HP84 42 in. Plasma HDTV
Acquiring satellites
Did you try reseting your nuvi?
Jul 09, 2008 | Garmin nuvi 350 GPS Receiver
I bought a panasonic DVD recodrer DMR-EZ485V for only 1 year. it was fine until lately, I turn machine on, within several minutes, it automatic shut off everything, can't watch DVD and can't record...
A fault within the switchmode power supply, unfortunately this requires attention from a qualified technician in an authorised Panasonic service centre. You can submit the unit to your nearest repair outlet - obtain a quote (on the likely costs involved including labour charges), and a second opinion (on the exact causes of the problem etc.) then you can make a firm decision on any further action after that.
This is not a DIY job, and if you still have a manufacturer warranty (or extended warranty) - take advantage of that and submit unit for warranty repair - at no cost to you except transport/shipping. If you do not have any warranty, and if replacement of the PSU board is required, the costs could be prohibitive. Certainly not unfixable.
May 31, 2011 | Panasonic DMR-EZ485VK DVD Recorder/VCR
2006 dodge ram 4x4 cummins with 48re changed trans gov and sensor now no overdrive
  1. Auto inspections of the vehicle may produce results contributing towards restoration. For example, the auto technician makes the evaluation as separate arrangement from which problematic areas are ascertainable. The result findings are documented as diagnostic draft plans from which repair authorizations are achievable. At which point, diagnostic without repair requirements would least requires any further procedures. However, once the vehicles diagnostics produce result requiring expert vehicle repairs, the next sequence of procedures are initiated. First, vehicle repairs require constituent components either permanent parts or depleteable resources constituents prior to workshop initiation plans. Auto technician diagnostic plans would usually contain the damage of the vehicle. A decision to commence restoration of the faults would produce estimate drafts in parts repaired for either replacement acquirable, leasable or alternately. The next sequence includes calculations estimates in resources that would be required contributing towards entire workshop restoration process procedures.
  2. Usually an evaluation auto expert may necessarily not have resource constituents for restoration to occur. An alternative arrangement includes acquiring component parts specified on diagnostic charts from elsewhere. Meanwhile the arrangement may be with the evaluations technician as repairs fellow once components were amassed. A diagnostic technician may provide the means to acquiring components when engaged as the repairs person however. Also, the type of auto restoration mode may require workshop environments with several signifance advantages. First, an auto workshop would usually provide environment where extensive tasks are achievable. For example, the auto repair environments require least obstruction to achieve success especially with tasks that may require undivided external obstructions with delicate technical process procedures. Second, auto repairs require workshops where installment facilities including huge to work box tools are prevalent to achieve repair works. Third, auto workshops provide the exclusive environment to achieve vehicle restoration.
  3. Usually an auto damage inspector would require fees for the expertise rendered as alternate arrangement. A result produced requiring pursuit arrangements may cost alternatively. For example, acquiring parts for that may be required to contribute towards restoration of damage decided from an auto evaluation expert is achieved at an alternate location. Auto parts stores would usually be a separate entity from the mechanical expert. Also, once the constituent parts for restoration the vehicle has been acquired, the same technician's expertise may be requested as separate cost termed workmanship fees. An alternate auto expert's consultation to restore the vehicle with the diagnosis plan, acquired parts, would involve separate cost arrangements.
  4. Usually, the likelihood of where vehicles damage requires workshop area only acquirable at separate arrangement may have cost fees. The condition attachments of the workshop may contribute towards cost fee explainable. For example, a leased workshop may require for auto technician to perform expediently else additional cost are incurred to the vehicle owner. Also mentionable situations where technician fee cost increase due to schedule arrangements found unsuitable either as working elsewhere inconveniently or being hurried to achieve report works are only mentionable conditions with auto workshop as alternate arrangements from the technician expert's responsibility.
  5. A damaged auto vehicle may require several arrangements contributing towards repairs least mentioned in technical responsibilities. For example, moving damaged vehicles between places prior to restoration may have been separate arrangement. Acquiring component parts that contribute towards restoring the vehicle is alternate arrangement. For example, component parts situated elsewhere requiring acquisition from the situation of vehicle or workshop, and technician expert contributes towards fee costs as amongst restoration conditions. Also requiring alternate arrangement prior to auto workshop commencement is fee cost calculations. An expert consultation may be required to ascertain the entire process contributing towards restoring a dame vehicle. For example, the documentation of the entire process has two advantages. First, throughout until the repairs are achievable, the documentations expert provides the details understood as feasible to achieve repairs. Second, the documentations expert provides the details as necessary processes until repair s are achievable. For example, the documentation is similar with accounting purpose requirements, record keeping, or even feasibility analyst for projects of individuals or businesses.
  6. The transportation efforts constitute in the repairing vehicles includes logistical resources that contribute towards restoring the broken equipment. Usually, consulting with an external entity as transport management responsibility has conditions. An example is consulting with towing transport establishments. A tow transport has several arrangements. Usually, the machine type requested has cost implications. Where size is significant factor in tow trucking. The larger a vehicle requires extraneous cost fees. Second, the responsibility request from the tow trucking has several requirements. For example, a demanding task from tow transport command huge fee costs. However, a rate fee makes the truck vehicle available. Several constituent arrangements of durational service request from the trucking establishment requests fee costs. Tow trucking establishment may have arrangement requirements contributing towards cost fees. Several examples are provided on acquiring transport for auto restoration peruses. First, the durational request of the truck ma have a charge cost where extensive duration has cost fees separate than least spans. However, the charge for acquiring truck transporting has fee cost separate from unforeseeable conditions. For example, requesting the truck may have transportation component arrangements where further off destination chargers from truck vicinity area are mentionable. Also, truck constituents like gasoline arrangements handled separately. The type of trucking establishment may require the costs of chauffer also conditional. For example, trucking may allow for requester to operate the device, else acquiring an alternate operator the device would become necessary commanding charge fees and costs
The vehicle's mechanical levers are joined together only separated at ball socket areas. Every ball socket area is lubricated to minimize wear though require durational inspections from which modifications may be achieved. The vehicles mechanical parts however least require replacement unless were malfunction with appropriate recommendation of change as solution. Mechanical parts however function with fluid lubricants that require replacement duration ally. A mechanical fluid however may last an entire expected length until the specified reinsapction without a situation of harm occurring prior to regular auto service inspections. However, the significance of mechanical fluids are providing lubrication for moving parts where the vehicle benefits in motion generation while the drivers acquire resourcefulness for the most part, and pleasant ride as contributory experience with proper functioning constituent components. Several mentionable factors makes vehicles component require frequent reevaluations. First, the type of conditions that are exerted on the vehicle determines the evaluation requirements. For example, mechanical power trains of a vehicle are overexerted with tasking functions either hauling, or repetitive engagement functionalities. Usually vehicles with dual functionalities may require separate checkup since over exerted parts acquire wear compared with remaining least enagagerable components. The components of the vehicle usually have durational inspection requirements. However, once observing malfunction requires evaluation prior to regular durational service inspections.
Jan 23, 2011 | 2006 Dodge Ram 2500
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
(TV) Remote Code for Panasonic TX 15LT2
For what is required, I will not pay $9. Obtained from a free site. Thank you anyway.
Jan 18, 2009 | Panasonic TX-15TA1 15 in. Television
Panasonic SC-AK750 Mini hifi
The problem is usually either the amp-pac or a regulator. If the problem is the amp-pac, expect to pay around $90 or so for the part alone. The regulator is much less. Yes the unit is repairable, but get an estimate on the cost as some of the newer units may be close to that cost as a replacement.
Dan
Sep 24, 2008 | Panasonic SC-AK75 Shelf System
Repeated Fax TX report printing
Solution #3 solved it for me. The report kept printing over and over, so I used the menus (roughly) mentioned in Soluton #3 by guest.
My problem was the printer was trying to print the TX Error Report with the image attached. That made the report too big for standard sized paper, so the machine kept telling me to check the paper size, and I'd hit 'OK', and that made the machine try to print the report again, for it continued to think it had not printed a complete report.
Here's what I did...
Go to: Fax Menu
Arrow right ( >) to Maintenance/Settings, hit, 'OK'
Arrow right to (>) to Device Settings, hit 'OK',
Fax Settings, hit 'OK',
Arrow down ( v ) to TX Settings, hit 'OK',
Arrow down ( v ) to TX Report, OK
Select 'Print error only', hit 'OK',
Attach TX image, Select 'NO', hit 'OK"
With the instruction to not attach the TX image, it will print out the error report without the TX image, the report will fit on the paper, and it will clear this problem.
Jan 22, 2008 | Canon PIXMA MP830 All-In-One InkJet...
I cannot acquire satellites signal. What to do ?
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching! The unit appeared to have "stuck" in this acquiring mode. The following worked for me: 1) open the GPS antenna 2) press the bottom left screen while holding the power button to turn the unit on 3) enter maintenace mode 4) select diagnostics 5) clear error report, do NOT clear any user data 6) restart unit the usual way My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Jul 21, 2007 | Garmin nuvi 350 GPS Receiver
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
