Question about Poulan Pe550 Gas Edger
How do i tell what type my model pe550 is - Poulan Pe550 Gas Edger
    Scholar:
  • 110 Answers
Its usually part of the serial number tag
Posted on Nov 01, 2009
How do the fuel lines in a weedeater trimmer pe550 hook up inside the gas tank
I have an older model that has a weighted filter in the tank. The filter flops around and can 'fall' into the fuel no matter which way you tilt the trimmer/tank. You should have one in your tank. Feed in the new line and make the end come out the gas cap. Push the filter/weight into the end of the fuel line. Pull the extra fuel line out of the tank to match the original position. You should have cut the new line to approximately the proper or same length as the old fuel line with an angle cut so you could push it into the tank.
Jul 23, 2014 | Poulan Craftsman/poulan/weedeater Fuel...
Which of the 2 fuel lines on PE550 edger is the steady fuel line for constant running?
Trace the hoses down into the fuel tank, the one with the fuel filter on the end is the main fuel line.
Aug 10, 2013 | Poulan Pe550 Gas Edger
My PE550 weedeater edger that won't stay running. I have new carb, new fuel lines, new starter coil. any idea what could be the problem? I am now checking the gas cap, breather is good
check your fuel lines ensure you have them on correctly also check spark plug clean if necessary also when you change out fuel lines and carb it may take quite a few pulls to crank cause the little fuel system has to get primed up!
Aug 09, 2013 | Poulan Pe550 Gas Edger
The screws that hold the carburetor vibrated out and are lost. Any idea what size they are ? SAE or metric ?
Here is your part. To see your whole machine, just select Weedeater PE550 and a couple parts diagrams come up. The part number with a photo and the price are here as well. Shipping is stiff, but this is the best I can come up with. The head is TORX 20 it looks like (could be T-15), but the thread style is the important thing. Good luck!
http://www.ereplacementparts.com/carb-screw-p-269854.html
Sep 06, 2011 | Poulan Pe550 Gas Edger
I need a diagram on how to reassemble the pull start.
Complete unit drawings can be found HERE.
On the right side of that page (under the "DETAILS" tab) click the plus sign (+) next to the folder labled "Illustrated Parts Lists".
The page with the pull starter is labled "Engine Assembly Type 3". Click on that and a new window appears with the complete breakdown.
Hope this helps,
Dolf-
Oct 16, 2009 | Poulan Pe550 Gas Edger
WeedEater Edger PE550 Starter Rope will not recoil
Order a new recoil spring from your suppier. It comes wound up. Remove the old part first usually four screws on the outside. Make sure the rope is fully wound then insert the new spring and reassamble. If it becomes unwound by mistake its a labourious job to rewind but can be done.
Aug 29, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Cant find anyone who will tell me how to adjust a homelite carburetor that only has one screw adjustment
Most devices will work ok if you screw the adjustment screw all the way in, then back off 1 and 1/2 turns.
Also, you might try a shot of ether-engine starter to initially get it going. As Always, have a fire extinguisher handy when dealing with these fuels. Good Luck!
Jul 03, 2009 | Poulan Pe550 Gas Edger
Poulan pe550 edger problem
Did you adjust the carburetur screws?
Sep 12, 2008 | Poulan Pe550 Gas Edger
Poulan Pe550 Gas Edger Logo
270 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
