Question about LG Shine KE970 Cellular Phone
Everytime i try to go into a function, i press a button and it doesn't respond, it will go into another area. i try to text and letters type into the box i didn't even type, i backspace and it starts to send the message, i can't reply. the buttons don't respond to what i want.
What is wrong with my laptop? It is as if the shift key is stuck
Go into device manager in windows and delete it and reboot. If it comes back when it detects the keyboard and it works then it was a driver, if it does detect it or it wont work correctly then it is a bad keyboard. You can also try a plug in keyboard to see how it behaves, ps keyboards are not that expensive.
Oct 11, 2015 | Toshiba Computers & Internet
My blackberry curve starting texting weird, i pressed 1 letter in a text and that letter plus 5 other letters would appear, til i got to the point i couldnt text at all. now its just went to screensaver...
Hi
seems like you have a problem with the keypad. may be a water damage or moisture damge keypad near the track pad. thats make your keypad malfunctioning and it just keep sensing like you keep pressing a key while even if you are not using your phone. you can try remove your battery and put in a bowl of rice for 1 day or you can try drying your phone with air dryer. if its still the same issue then you may have to clean your keypad contact. thanks.
Oct 16, 2011 | RIM BlackBerry Curve 8520 Smartphone
What do I click for desktop, I'm trying to enlatge my text?
Hello rddecooman,
to change the size of the "Letter, Numbers, and "Icons...
Do the following:
"Right" click on an 'empty area' of the "Desktop."
Next, select "Personalize" from the 'shortcut menu'.
In the [Left] side of the 'window'; click on the "Adjust font size (DPI).
This will change the "Size of the Letters, Numbers..."
Click on the {Radio Button} for the "Larger scale (120 DPI)."
Now, just below!
Click on the "Apply and OK buttons, before you 'close the window'!
"Your "Letters, Numbers, and Icons will be 'Larger'.
If there is anything else you need help with?
"Write a 'comment'; I'll be here to assist you!
"Best Regards
Aug 15, 2011 | Computers & Internet
When I type letter keys, numbers come up with the letters
check your keyboard: T and 5 are relatively close to each other. Try to clean the area under keyboard buttons especially these two buttons. may be it can help you.
Sep 07, 2009 | Toshiba Satellite A105 Notebook
When typing a text, I can't pick the letters or numbers I want.
that means your messaging font is set to type the word for you. find "options" then look for soomething that ays "abc" your phone is set to type in "t9"
Apr 09, 2009 | Nokia 6085 Cellular Phone
HTC P3400i messaging and hangup problem???????/
try this if it helps
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to www.htc.com for latest Rom update downlaod and update backup ur data first
Jan 28, 2009 | HTC Touch P3450 Smartphone
Trouble entering message into itext sms text messenger
I updated someone else's instructions to make them more clear...
Instructions to a Sakar sms text messenger - sending text messages.
Press the NUMBERS/LETTERS below the keypad icons.
Example: SEND a message from one Messenger to the other
  • For the messenger (USER 1) receive a message
    • Press SMS button,
    • then the RECV button and leave it like that - don't do anything
  • On the messenger (USER 2)sending the message
    • Press SMS
    • Type with the numbers/letters (NOT THE PICTURE)
    • Click SEND (it will display P/i ?)
    • click the (I C Q chat) button with the smiley face
  • The message will appear on messenger (USER 1) display
Dec 29, 2008 | Sakar Cyber Gear Slide Click Text...
My tmobile dash keeps going back to the home screen
Hi jamari140,
A few questions to get a better idea of what this might be:
1) Are there any applications that open successfully?
2) Which keys/buttons are you pressing to enter these apps?
3) Have you been experiencing any issues with the keyboard (incorrect key sequences or letters, etc.)?
Please respond to the above and we'll dive a little deeper into what's going on here.
Thanks!
Jonathan
Sep 30, 2008 | T-Mobile Dash Smartphone
LG Shine KE970 Cellular Phone Logo
52 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
