Question about HTC Touch Pro Smartphone
Hi, I have my O2 XDA Orbit, I am unable to boot the device, It keeps saying "The device is unable to boot because either you have turned off the device incorrectly or tried to install an application from untrusted source. Press END to reset your device or press any other button to cancel. This operation will delete all your personal data and restore the device to its factory default settings." Don't know what happened suddenly. Could you pls assist me on that. Thanks in advance..
Hello there After a soft fall on the carpet floor, my xda orbit 2 says install sim and internal speaker is dead. Thanks for any advise
open xda orbit 2 and ensure all hardware is connected, just take it to bits and rebuild it..
could be a loose connection or worse, broken connection.
Nov 22, 2009 | O2 Xda Orbit Smartphone
My o2 xda orbit mobile when switched on does not sustain. It gets off by itself. But if I keep on pressing the on/off switch at an interval of say 30 seconds the mobile keeps on as long as I continue doing...
at the moment im currently finding a soloution for this on my own xda orbit. im going to start by dismantling the phone to see if there is a loose connection etc..
also gona try hard reset if it still persists but if it dont work i think its an issue with the battery which id get off ebay, they cost about £5 but ill try these first before i spend money, ill be doing these tonight so ill let you know what happens tomorow.
Oct 15, 2009 | O2 Xda Orbit Smartphone
Xda orbit 2 won't start up
sir plz its same problam with me thanks
svicky2001@yahoo.com
Aug 11, 2009 | O2 Xda Orbit Smartphone
Want pc suite n driver for o2 orbit2
if u mean that u need update for ur Xda then follow this link here
http://xda.o2.co.uk/software_updates.jsp
and select "Xda orbit 2" and press continue
then press the second continue button
enter ur Xda serial to validate
then select agree
click submit
Aug 10, 2009 | O2 Xda Orbit Smartphone
How can i hard reset my o2 xda orbit?coz i 4get ma password..
To do a hard reset.
Press both soft keys and insert stylus into soft reset button and press.
Release the soft reset button and keep pressing the soft keys.
When the "This operation will delete all your personal data, to manufacturer default" appears on screen.
Press Green call button to restore manufacturer default, or press other keys to cancel.
source
http://wiki.xda-developers.com/index.php?pagename=Artemis_Resets
more helpful information about your device:
http://wiki.xda-developers.com/index.php?pagename=HTC_Artemis
Let me know if you need anything else.
Thanks,
Ekse
Mar 07, 2009 | O2 Xda Orbit Smartphone
Blank white screen xda orbit
The only solution is to format your phone but you will loose all data.
Jan 11, 2009 | O2 Xda Orbit Smartphone
I am having problm in hard reseting my o2 xda orbit phone...can you help me?
By a hard reset I presume you mean resetting to manufacturers default settings?
If you can boot your device, the easiest way is to go to Start > Settings > System Tab > Clear Storage.
If you cannot boot into Windows Mobile on your Orbit then the best way is to hold down both the left and the right soft-keys (the two keys with _ marked on them, either side of the wheel) at the same time whilst you poke a paperclip (or similar pointed item) into the reset button on the left side of the orbit. This will initiate a hard reset on the device.
Nov 27, 2008 | O2 Xda Orbit Smartphone
No power to xda orbit
Hi ref my xda it has been taken back by o2 and i will get a new one from them next week i hope it does not happen again fingers cross watch this space for up date on this
Feb 29, 2008 | O2 Xda Orbit Smartphone
O2 XDA Orbit circuit diagram required
log on to http://xda-developers.com i hope this will solve your problem
all the best
Jan 25, 2008 | O2 Xda Orbit Smartphone
HTC Touch Pro Smartphone Logo
60 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
