Question about Cavs JB-99 3-Disc CD Changer
Jb99 wont power on in the past there was some code like stop 3 stop stop or something (some boot code) does anyone know this
Visual Land Connect Android 4.0 wont boot
Hold the power down and press the -volume button down to reboot
Sep 29, 2012 | Visual Land Connect Android 4.0 Internet...
My imac wont start . power has been a problem , anyone had the same problems. Over the past 3 months it will close down after 2 mins, I would rebootit and it would be ok, Now it just wont start? Anyone...
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
hope this helps
Sep 04, 2012 | Computers & Internet
My compaq wont boot past the compaq logo all it does just sit their and i try to hit esc. f1 or f10 it still does nothing it used to boot up every 2 or 3 days after it off a while and now i change the cmos...
several people have reported the same issue, the only person I can see who solved it was to do a complete windows xp installbut I am not sure how he achieved this if the machine wont post. First thing I would check is how secure any add on cards or RAM sticks are, disconnect your machine from the mains, take the side off, touch the casing to discharge any static you may have in your body, then go around the mainboard, reseating each part. Just take the part out and put it back in again, It could be that something has been knocked and isnt connecting properly.
May 05, 2011 | HP Compaq Presario SR1320NX PC Desktop
My Ibook A1005 (2002) model,just wont boot up,I press the power on button,the Apple sign comes up,and it just continues to load with no results!!!!It was working just fine,can anyone assist me
If your iBook loads to the Apple logo with a spinning gear beneath it but does not progress past that point, follow the instructions in the following article to attempt to resolve the issue:
http://support.apple.com/kb/TS2570
May 18, 2010 | Apple Computers & Internet
Ps3 no video or audio
big red
check your rca might be broken
Oct 25, 2009 | Sony Playstation 3 (PS3) Console
My sidekick 3 wont go past BATTERY LOW! PLEASE ALLOW DEVICE TO ..
turn off your phone. then remove the battery for 5 minutes. also make sure your charger is not plugged in. then put the battery pack into the phone. it should clear up. also you might have over charged the battery. another solution is to buy a new battery pack and if that does not work your phone is acting up on battery basis
Jan 20, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Freezes up at 3/4 boot 90% time
when u power up the computer press
F8 key then enter in safe mode.then tpye in run"chkdsk /r"
then press "y"
then restart the system.then it fixes error on harddisk.scan your computer with latest updates antivirus.
Jan 05, 2009 | Computers & Internet
Computer wont boot
yep you said it loose connection, wiggle the power cord and and thing attached.
Jan 08, 2008 | Computers & Internet
Cavs JB-99 3-Disc CD Changer Logo
Top Cavs Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cavs Audio Player and Recorder Expert? Answer questions, earn points and help others
