I have an brand new Vizio SV470M LCD. It was an open box purchase so the warranty in null and void. I am getting heavy pixelation on the screen and lines that run vertical on the screen. When I first turned on the TV it took a few minutes to happen. If I shut it off and turned it back on it would go away temporarily but eventually come back. Now is happening when ever I turn it on.
  • nathanpalm Sep 24, 2009
    Vizio told me they could not honor the warranty so that is out the window. The place I bought it from was liquidation.com. I sent them an e-mail that the manifest for the TV provided false info, so Ill have to wait and see if they can do anything.
    Do you know how much it would cost to have it repaired out of pocket? I also had a guy at a repair shop tell me that I might try popping the rear panel and re-seating all if the video connections to the boards. Do you know anything about this?
    Vizio told me over the phone that they cannot accept the warranty. What would it cost to have the panel replaced out of pocket? I had one tech guy from a local shop tell me he thought it might just be a loose connection or that the connections need to be unplugged and reseated on each internal board. Any thoughts!?!
    President:
  • 2,923 Answers
There are lots of possible cause of the problem, it could be:
- Bad solder connection
- Burnt Integrated Circuit (IC) or capacitor.
- Automatic format switcher is not working properly.
You really need to consult a TV technician to identify which component is bad.
Have a great day!
Posted on Sep 24, 2009
  • 333 Answers
The panel is going bad. Or that is, it sounds like it has gone bad. I had a samsung lcd tv that was brand new in the box and within a month it was replaced twice by samsung. There is always a bad apple in the bunch.
Even though it was an open box and the store you bought it from won't honor the warranty, the manufacture still will. A warranty is a warranty regardless of whether it came in a box or not. As long as you have a receipt, and the purchase was within a year, they will fix it. They don't need to know it was an open box.
Why is there a grey band on my new tv
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Feb 07, 2014 | Vizio SV470M LCD TV
I have a vizio sv470m that only the top 2" of the
Check the flat connection wire [LDVS] cable that connects the T'Con board and LCD panel for any loose contact. Re-set it once and check. If it do not help yoy, the T'Con board should be replaced It is faulty. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. http://electronicshelponline.blogspot.com/
Apr 30, 2013 | Televison & Video
Where can i get a new screen for my 47"vizio hdtv
Ouch, will most likely cost as much as a new set. You can try Shopjimmy.com, retechtv.com, or EBay.com
Jan 17, 2013 | Vizio Recertified - 47" Class 46.96" Diag....
Vizio sv470m
Try unplugging all units involved for a while--make the HDMI connection when they are disconnected from power--HDMI does not like being hooked up to units that are powered and or on.
Jun 14, 2012 | Vizio SV470M LCD TV
Three weeks ago purchased a Vizio xvt423sv 42".
There are lots of problems. The best thing to do is have it replaced completely while under warranty.
Jan 09, 2011 | Vizio XVT423SV 42 in. HDTV-Ready LCD TV
I Can see pixels on my Vizio SV47OM. How do I fix this
if they are in a line from top to bottom ...bad lcd panel
May 02, 2010 | Vizio SV470M LCD TV
Dark spot on right side of LCD screen in the shape of Illinois has appeared gradually over the past few weeks. Very noticable between commercial and when news channels show graphics/slides. Pixels are not...
In most of the case, the problem is a defective display LCD panel, this problem in some terminology is called PIXEL RETAINING, it means the pixels are locked up, there is no good permanent solutions for it, you have to change the LCD panel.
Jun 02, 2017 | Vizio L32 32 in. LCD HDTV
Horizontal line at top of screen in any hd format with componet or hdmi. model is sv470m. the tv isn't even a week old.
Get into the TV menu and locate the H (Horizontal) and V (Vertical) picture options. . .increase the V until line at the top is gone.
Oct 20, 2009 | Vizio SV470M LCD TV
Vizio SV470m with a pixelated screen after being on for 5 minutes
verify if it only happens on the antenna/cable input and if it works fine with dvd or other input, then it is a signal issue with the cable or antenna u r using and repair that problem and not the tv
Sep 24, 2009 | Vizio SV470XVT 47 in. LCD TV
Green shadows appear on new visio SV470VT. Very
It maybe a circuit control board for the screen. Last thing you want to do is void the warranty by opening up the TV.
Best to use the warranty at this point. Here's info to get you started.
Phone Numbers
Technical Support or To Place an Order
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
techsupport@vizio.com
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
Jun 28, 2009 | Vizio VO47L 47 in. LCD TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
