Question about Canon PIXMA MP160 All-In-One InkJet Printer
Image has a white stripe through it, with light black horizontal striping across each light stripe
    Sniper:
  • 70 Answers
Go to printer maintenance and perform deep cleaning, do this for 3 times. Then print nozzle check to see which color has a problem. If you still encounter your problem all you need to do is to replace your cartridge.
Posted on Sep 24, 2009
I have a kodak 4600 scanner that has an error " white patch not seen". i have tried to cleaning the imaging guides and calibration as wellthe scanner does not calibrate too please how can i resolve this.
Hello, I had a similar problem. The guides have a white stripe facing the camera (facing the inside of the scanner), the scanner uses this white stripe to define the image. If the guides are in place, and you turn the scanner off, you can see there is a black tape on one of the borders of the guide it is black on one side, and white on the other. You can take the guides off, and check if you can see the white stripe, sometimes this stripe has some scratches, or is not completely white. You can try placing a white piece of paper of the same size as the white stripe on top of the existing white stripe so that it serves the same purpose, if that does not work, you might need to take the black tape that has the white stripe on it, and try to replace it. The scanner needs that white stripe to be completely white. Hope it helps
Feb 26, 2014 | Kodak i1440 Pass-Through Scanner
Toshiba eStudio 2830c-getting a light line across
Hello sir; Is the stripes allway in same place and you use document feeder to copy, then you have to clean up a piece stripe glass on the plateform, otherwise ,you have to change drum cleaning blade or drum cartridge.
Dec 24, 2009 | Toshiba Office Equipment & Supplies
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
Im installing a new sterio in a 95 mustang ----i need a colour code dia. of the wires on the old factory sterio. Which wire goes where?
A Right Rear Spkr (-) Dark Brown w/ Pink Stripe Purple w/ Black Stripe
B Right Rear Spkr (+) Tan w/ Green Stripe Purple
C Right Front Spkr (-) Green w/ Orange Stripe Gray w/ Black Stripe
D Right Front Spkr (+) White / Green Stripe Gray
E Left Rear Spkr (-) Tan w/ Yellow Stripe Green w/ Black Stripe
F Left Rear Spkr (+) Tan w/ White Stripe Green
G Left Front Spkr (-) Lite Blue w/ White Stripe White w/ Black Stripe
H Left Front Spkr (+) Orange w/ Green Stripe White
I Amplifier Turn On Do Not Use For This Vehicle
J Power Antenna Turn On Do Not Use For This Vehicle
K Ground Wire Black w/ Green Stripe Black
L Do Not Use For This Vehicle
M Dash Light Dimmer Wire Orange (if available)
N +12 Volt Ignition Wire Thin Black Wire Red
O Do Not Use For This Vehicle
P +12 Volt Battery Wire Green w/ Black Stripe Yellow
Jun 17, 2009 | 1995 Ford Mustang
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Horizontal stripes on images
may be the ink level in ur ink jet printer is low try and use genuine ink for ur printer . i also have the same problem . when i replaced with original ink it gets ok
Dec 03, 2007 | Canon BubbleJet i560 InkJet Printer
White "Stripes" across page
REPLACE PAPER AND THE INK CARTRIDGE
May 14, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
254 people viewed this question
old marine
old marine
