Question about Liebherr KB4250 Refrigerator
I have a new lieherr refrig with freezer on the bottom. was told have separate motors. no drainage bin. water collecting under plastic bins and onto floor - while we were home. (not collecting when we were away), probably has to do with use and temp of foods being stored. I think the little black(gasp - with mold) hole in the bottom left third of frig unit may be plugged to get to that pan where someone mentioned an evaporator fan. what is the best way to unplug - sounds like threading a tube with a syringe might work. Couldn't wire scratch? How strong should the clorox be? Thank you.
  • charley
    charley Dec 07, 2015
    in the pan on bottom of fridge there is a drain most likely clogged with the black mold...i had the same thing. use 1/2 cup white vinegar and 1/2 cup water and use a turkey baster and put that though the drain. I also used some mold and mildew cleaner with bleach around it, used q-tips to get to tough parts and something to actually stick down the hole to try to dig up any gunky mold. (pipe cleaners, toothpicks) I suppose this vinegar solution should be used on some kind of schedule...I plan to do it once a week from now on.
    Sergeant:
    Champion:
  • 255 Answers
Find drain pan under fridge and blow back up threw hose with air. shop air, your mouth, or foot pump for air bed.
Posted on Sep 24, 2009
I have a Whirlpool refrig./freezer. I have no problem with the ice dropping in the bucket,but when I try to dispense it under the chute,it wil not dispense. The water works fine. This is a side side ...
Sometimes the ice will collect, melt, and freeze into a giant headache. If you have the one where you can get ice out of the holding bin inside the freezer, see if the ice bin will come apart from the rest of the dispenser. If it doesn't come easily, get as much ice out of the bin, get a wet vac ready and pour warm water on the ice. It will run through the dispenser. Once things come apart easily, you can take it over to sink and get rid of the ice blockage with warm water, let it dry, reinstall, and check to see if it works. Hope this helps.
Nov 03, 2013 | Whirlpool 21.8 cu. ft. Side-By-Side...
Water is pooling under vegetable bin at bottom of refrigeraqtor. Seems water is coming from insude refrigerator under freezer shoot. Placer plastic cup under it and it has collected water that froze....
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 19, 2010 | Whirlpool Refrigerators
Water collects in bottom of refrigerator under fruit/vegetable bins
When a fridge goes in to defrost it melts the ice on the coils in the interior of the freezer. Often times there is a drain that runs to a sliding tray under the fridge. If this is clogged you will get water building up under the bins.
Jul 10, 2009 | Refrigerators
I have water collecting in the bottom under the veggie bins of a freezer on top refrig.
you have a ice/drain problem get to the back of the freezer and take the cover off and see what you got...
Jun 24, 2009 | Refrigerators
Water collects in bottom of refrigerator and gets in bins
there is a cup in the back wall of the fridge that is the drain pull it out gently and clean it plus take a small hose and blow through the small hole if there is no cup check under the crisper to see if the drain hole is there
Apr 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water runs under the vegetable bins
There should be a collecting channel with a hole and a tube reaching down to somewhere above the cooling compressor (Back of unit) where it should evaporate with the heat.
Most people never clean that hole and tube simply because they do not know what is for or the manual is silent. Sometime can be jammed with little icecube. I us thick plastic line from toy to clean, electrical wire with copper core not naked is also oke. Do not put wild force. This is the cooler part. The deep freezer part needs defrosting on temporarily basis and for that you need some small low bin to start collecting or keep on mobbing the floor.
Apr 14, 2009 | Magic Chef Refrigerators
Ice maker is dripping into ice bin after water refills?
I had this problem on my refrigerator. I talked to a service tech at the local appliance dealer and here's what he said. There is a valve at the back of the refrigerator (mine is a side by side, but the basics are the same When the Ice maker goes thru it cycle, a part of that cycle is to turn on the water to fill the ice tray, then the next portion of that cycle is to turn off the water. What is happening is that the valve is getting the signal to close but due to mineral build up on the valve surface it is not able to completely shut off.
The solution is to replace the valve. This is not difficult. Turn off the water to the refrig. It's usually runs under the cabinets to the sink and you can see a plastic hose under there with a small handle you can turn to shut it off. Pull the refrig out so you can get to the back and you will see the valve. It will be connected to the same hose that is under the sink Remove and replace the valve. make sure all the little hose fittings are tight. Turn on the water under the sink and check for leaks.
Hope this helps PS you can get a new valve at most any appliance dealer.
Good luck Loringh
Oct 24, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Hotpoint refrig model CTX21EPJR
there is a drain gulley on the back wall with a drain in the middle. this drain is blocked. push something flexible down it and follow up with a small jug of water to make sure it flows away freely
Jul 06, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Liebherr KB4250 Refrigerator Logo
331 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
