Question about Compaq FP 7317 17" LCD Monitor
No sound coming from speakers
I have a compaq fp7317 moniter 17 inc and only the right speaker gives
sound at times nothing at all from the left
  • 3,866 Answers
You ether got a short in there or the plug cable has a short ether way this needs to be looked at a quick fix would be to buy seperate speakers.
Posted on Sep 24, 2009
Bought a new compac computer and I can't get any sound from my HPvs15 monitor
Be sure to connet the sound card speaker and install sound drivers for the moniter to get it to work you can go to http//www.hp.com select compaq and slect your model to download the correct drivers, also make sure you don't have any speakers muted in the mixer driver by double clicking on the speaker on the lower right hand corner on the lower right hand corner.
Jul 16, 2010 | HP vs15 15"LCD Flat Panel Monitor
Want to have four speakers
Buy a mini stereo splitter from Radio Shack
Dec 31, 2008 | Compaq 17" Flat Screen CRT Monitor
No speaker hook up on new moniter
If your old monitor was a Compaq, it had slots for the speakers to hang on and provided the power for the speakers. The speakers still got their input from a cable that plugged into the computer sound output jack. If those speakers are the style Compaq supplied when I worked at a Compaq service shop, they originally came with metal stands that fit into slots on the back so you could stand them up on their own, and a 12-volt power adapter so you could use them without the monitor. If you don't have those pieces, you can buy a suitable power adapter (12 volts DC at 1 amp) at Radio Shack but the speaker stands are hard to find. You could try eBay, or just make a holder of some kind. (A friend of mine used those little wooden stands you can buy to display plates to hold her speakers when she got a new monitor. They worked out pretty well.)
Or you can replace the speakers. A new set would have everything you need. But those Compaq speakers sounded pretty good, so if they're still working you might want to keep them.
Dec 22, 2008 | HP Compaq Computer Speakers
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
New moniter old computer
does monitor have speakers if yes it will have a speaker connection with the video lead connect it to speaker output on computer.
If monitor does not have speakers you will need to buy or use external ones
Jul 15, 2008 | Computers & Internet
Compaq wf 1907 monitor speakers--no sound
make sure they have not came unplugged from the computer also on many keyboards there is a mute button, make sure it has not accidentally got pressed
Jun 06, 2008 | Compaq Presario 5000 PC Desktop
Speakers not working
Your problem is prevalent anywhere , whosever around the world,,, you had tried everything but nothing happened? Well , the porblem is internal....if you are a hobbyist, you may open your monitor and try checking the circuits where the speaker is being located, check for loose solder. busted wiring , or the speaker itself, maybe one of the wires is cut or dislocated. Word of wisdom,,, bring your monitor at nearby electronic shops if you wish spend a little of your savings. This way you may out of electric shocks if you do it after all. Leave it to the experts....good luck
Apr 03, 2008 | HP Compaq Computer Speakers
Get Moniter Speakers Working
Hello First of all you need a sound card on your computer with a Spk. (Speaker) or Phones (headphones) Out Jack it might be a symbol of a small speaker or headphones. You have to be sure you are getting a actual sound output signal from this sound card too. If the sound card is not working your moniter speakers would not have a signal to drive it. You also need a 1/8" Stereo 2 male stereo plugs on both ends, one end plugs in back of moniter other plugs in back of computer like I mentiond above. Make sure your Mute button is not selected on your computers volume button usally at bottom right of screen. Make sure the volume buttons are up to aprox 3/4 up also. Then for last on the moniter look in the menu i think you might have to keep pressing the menu button but i kind of forget now but its a Spk setting and volume setting in this speaker setup within the moniter as well make sure this is turned on and set at a higher volume level as well. Thats about all I can say without taking the moniter apart and checking the jack and wires and speakers. I would suggest you take it to a electronics or a tv repair or computer repair person to go any further then this. Hope you take time to read all of this I tried to put every step in here to help anyone out with this problem. Thanks for reading. Ken T
Nov 08, 2006 | Liquid Video A170E101 Monitor
Compaq fp7317
I suspect that when you reattached the monitor back you might have moved the agp card out of her slot. Check if you have connected properly your monitor to the pc And if the agp is in it's slot properly attached. Hope it helps, good luck!!
Feb 14, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
Compaq FP 7317 17" LCD Monitor Logo
220 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
