Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I keep getting black ink is out its a new cartridge and new print head
  • 3,866 Answers
You are going to need to replace the control sensor in this printer as well as its in malfunction.
Posted on Sep 24, 2009
The black ink keeps drying up and will not print out black print
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Jan 03, 2013 | Canon Cli526 Black Cyan Magenta Yellow 3x...
Hi, I am having a problem with my relatively new canon ip100. Since I installed new cartridge for black ink, when I run the test of nozzle it shows that black print head needs cleaning: missing parts lines...
Welcome to FixYa!
Here are my suggestions:
Confirm that the Ink Tank is installed properly.
If the ink tanks are not loaked into place, the will not be supplied to the print head.
Remove tape from the
The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
Confirm there is no orange tape across the top of the ink tank.
Try to use other Black Ink Cartridge. The cartridge might be defective.
I hope this helps.
Thank you for using FixYa.
Keep me posted.
Jas247
Mar 31, 2011 | Canon iP100 Portable Printer
My black ink ran out so I replaced the ink
Hi:
I have used the printer series that you have for years, and once in awhile, I get a new cartridge that won't immediately print. Often, there is just a bit of dried ink residue on the print head, and that won't allow the cartridge to work correctly.
Some simple things to try are :
1) Remove the black cartridge. and take a damp paper towel and gently swab the print head area. Next, apply some pressure to the sides of the black cartridge, until you see black ink oozing out of the print head. Repeat if needed. Once the ink starts flowing, blot off the excess, and install the cartridge.
If you can't get ink to flow, then the cartridge might be bad. Most of them have an expiration date on the packaging.
Mar 31, 2010 | HP DeskJet 960c InkJet Printer
Installing a new black ink cartridge and i keep
chech the part number of your cartriges, and also the expiration date for both cartridges
Mar 17, 2010 | HP PSC 2110 All-In-One InkJet Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
Not understanding why there's two black ink cartridges
One tank is reserved for colour printing and the other one is for grayscale printing ( Black and white). Watch out as when you run out of ink and you keep trying to print a document with empty tank cartridge it will cause your print head to go bad. The cost of a new canon print head is the same as the cost of a new printer. Canon over priced the print head.
Nov 30, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Ink well cleaners
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
74 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
