Question about HP PSC 2355 All-In-One InkJet Printer
My printer always jams the paper in the right corner when the paper is fed about a quarter inch over the top of the rollers and into the ink cartridges. I'm not really sure what's wrong with it but I suspect something with either the rollers or some other little plastic piece in the printer.
  • HP Master
  • 3,866 Answers
Could be ether the roller needs lubercation or something getiing in the paper gidepath you need to check for both, pretty much if its a roller that would be a easy fix also try using a thin grade paper.
Posted on Sep 24, 2009
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
Ink there. My printer does not pick up the paper fron the tray. It only picks it up when I use thick paper and I help it with pushing it into the machine. Always the smart panel telling me there is a paper...
The pick-up roller at the rear of the printer probably needs to be cleaned using an alcohol solution as over time it picks up dirt and ink from the paper being fed through the printer, especially if printing on both side by turning the sheets over.
Oct 27, 2011 | Samsung CLP 300 Laser Printer
When the paper is fed it is pulled in w/ the bottom right side of the paper going in but not the left side, it becomes uneven and ends up jamming - what would be the reason it would grab and pull the right...
The most likely cause of the problem is an obstruction on the left side of the paper path - most likely a shred of paper from a previous jam. You can estimate where to look by how far the paper goes in before it starts to twist to the side. Sometimes I've had to use a dental pick to snag a shred buried deep inside as an alternative to dismantling the printer. You may find it helpful to use a small mirror to look underneath or behind rollers while you search for the culprit.
Another possibility is one side of a dual pickup roller (two rollers on a single shaft) is worn out. That is unlikely; except for large format units most printers use a single pickup roller.
Jun 06, 2011 | Epson Stylus CX9400 Photo Printer
Feed jam
1) Be sure the paper tray is inserted all the way in.
2) Be sure you're using the right size of paper (width, length and thickness; paper that is too thick may jam a laser printer if it is not configured properly)
3) Be sure you're using the correct TYPE of paper. Paper designed for ink-jets sometimes produce paper jams on laser printers.
4) If the paper was jammed before, you may have a small piece of paper jammed in the printer rollers. Open the printer and very carefully look for small pieces of paper on the rollers and all the paper paths.
5) Also, some printers are very picky about how much paper you have in your paper trays. Place enough paper on the paper trays so that it is about 3/4 full, no more, no less.
6) The paper rollers that pick up the paper may be dirty with dust. Use a q-tip and 2 drops of rubbing alcohol to wipe the rollers clean. Rotate the rollers with your fingers to be sure that all the surface of the rollers are wiped clean. Be sure to use 91 % rubbing alcohol; carefully read the label of the alcohol and use the one that DOES NOT contain anything except rubbing or isopropyl alcohol and water, no glycerin or any other additives. Wait at least 1 hr before using the printer again to be sure that the alcohol has completely evaportaed .
Please, report back if you need further assistance.
Mar 31, 2010 | Samsung CLP 315 Laser Printer
My HP LaserJet 3050 will not grab and feed paper from the paper tray but will print on single fed sheets when fed to the input above the paper tray. What is wrong?
Open the top as if you were going to change ink cartridges. Find all rollers yuou can and wipe them with a t-shirt type material dry. Do not use any liquids unless you can get some rubbing alcohol. Turn the wheels and claen them as best as is posible. Open the paper jam door and do the same to all rollers in site. Any way you can get to the rollers, use it. This should solve your problem. Also try fanning your paper before loading it. Thanks, Dana
Sep 04, 2009 | HP LaserJet 3050 All-In-One Printer
I have PIXMA MP 600 PRINTER that has a paper jam as I fed used paper back into it /ink was still wet and apparently paper has stuck together and jammed. How do I clear
clear the jam paper
1) pull slowlly the jam paper back as possible as you can, usually the jam paper could be broken as pulling
2) open the cartridge area find the paper pull slowlly forword paper direction as possible as you can and try to take out any pieces paper behide the cartridge (between paper input roller and ink cartridge
Jan 24, 2009 | Canon PIXMA MP600 all-In-One InkJet...
ERROR: Paper Output Jam
HI i just recently 5 min ago fixed this problem.....I tried for days. Most likely something like in my case a small bobby pin fell in the back tray and went into the machine. Some people turn the machine upside down and shake it to get whatever it is out.. nothing fell out of mine when i tried this.. I had to take off the left side of the machine panel ,,,2 screwss in the back and pry down and outward there are 2 screws in the front as well under the silver corner push downward on edge.
I held a piece of paper in front of the front roller and revese fed it into the machine by turning the exposed "wheel " on the left side. You have to guide it through lift up top to see in there as the paper goes under the white rollers. At this point the paper may jam so look inside top at the white rollers about an inch from the right there is a small rectangle shaped hole in there is a black plastic part that part needs to be lifted with a paperclip so the paer can be feed under it,,,,at that point is when the paper i was reversing pushed out a bobby pin.....now mine works great again......main thing here is there mostlikley is something clogged in there,,blocking the paper.........also check you paper that gets stuck my paper kept having a bend in it where it jammed and thats where the pin was in there.
Sep 24, 2008 | Canon PIXMA MP470 All-in-One Printer
Paper jams/ printing blank
Thoroughly check for very small foreign objects in your printer, and check both behind in paper feeder area and inside the unit. Jams can be tiny pieces of paper than have gotten in or torn off paper fed in at slight angle but you may not have noticed. Service you printheads and rollers both manually with solution and cotton buds (q tips) and then see if your ink may be low or out, blocked printheads will obstruct ink from flowing at all. So will damaged printhead points on cartridge, signalling replacement time.
Aug 14, 2007 | HP PSC 1215 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
