Question about Samsung SGH-E900 Cellular Phone
Hi!there! see i have samsung sgh B520! i need to download java games for my mobile via usb cable! i downloaded games which can run in my phone and the file was jad/jar(into memory card), but when i open the my memory card and go to other files which has all the downloaded games, i am not able to install and it says 'not allowed' when i press it! please help!
Cannot install java on samsung i640
Im very sorry Dude
  • It is NOT officially possible to install java MIDlets on samsung handsets (excluding smartphones) via bluetooth, IrDa, USB cable or serial cable. MIDlets can only be downloaded by Over-The-Air (OTA) via a download server
  • There is currently no method for installing MIDlets on other platforms other than by OTA/GPRS via a download server.
BUT THERE ARE SOME UNOFFICIAL METHOD PLEASE TRY THIS BUT RISK IS WITH U.
Install JAVA games on your Samsung via a USB cable, BT or even an IR port
The method here is rather straightforward. It has been tested on my two D500 phones without a single problem biggrin.gif
1. Download and install Softick PPP from here. The software is designed for Palm users, so if you receive any error messages such as unable to locate USBPORT.dll, just ignore them.
2. Active your IR connection or hook your USB cable into the phone.
For IR users, you need to active the IR connection on both of your laptop and D500, and approach the laptop with your D500 to let it find the phone prior to any transferring.
For USB connection, the one I tested is from fonefunshop
3. Start Softick PPP, and check if it has your connection in its 'Settings->Bluetooth/Serial'. Active it if done.
4. Run 'Uploader.exe' program and add a jad file.
5. Enable Serial Java download - #*536963#.
6. Enter Serial Java menu #*5737425#, and choose USB from "1 PPP UP'. Please bear in mind, just do it once for each switch on/off!
Select second option - "2.Serial Download"
7. Let upload and softick PPP access the net if you installed a firewall.
-More details--------------------------------------------------------
If you are using a USB cable, please take the following steps:
1. deactive Softick PPP, and exit it.
2. connect the cable,
3. run Samsung's PIM & File Manager to make sure that you get connected. If not, please switch off and on your mobile and try it again.
4. run Softick PPP
5. go to it's 'Settings->Bluetooth/Serial' to check if it has a connection such as COM7 Devicess_mdm0. If so, select it, otherwise exit the Softick PPP and go back to the first step. (you may find the proper COM setting from the windows device manager->modems->Samsung Mobile USB modem)
6. active Softick PPP.
7. run Uploader.exe
8. ......
For IR users,
2. active your IR connection。
3. approach your phone to the laptop, and make sure there displays an icon in your tray area and it gives a message 'there is a device around....'
4. run Samsung's PIM & File Manager to make sure that you get connected via IR. If not, please switch off and on your mobile and try it again.
5. run Softick PPP.
6. enable IRDA interface support in 'Settings->Options'
7. go to it's 'Settings->Bluetooth/Serial' to check if it includes a connection such as 'COM4 Device
Jun 26, 2009 | Samsung SGH-i640 Cellular Phone
Installing java games to a SAMSUNG E250
You can only download the JAVA Games from the WAPsites using GPRS.Samsung E250 do not have a facility to run games when transferred from data cable
May 22, 2009 | Samsung SGH-E900 Cellular Phone
HOW TO INSTALL GAME IN MY SAMSUNG D780 MOBILE
  • It is NOT officially possible to install java MIDlets on samsung handsets (excluding smartphones) via bluetooth, IrDa, USB cable or serial cable. MIDlets can only be downloaded by Over-The-Air (OTA) via a download server.
  • A hacking method has been devised for phones with the Dragonfly platform (see post #1 for platform list). All java serial codes discussed in the forum apply to phones with the Dragonfly platform only.
Try this link to understand the crack : http://forum2.mobile-review.com/showthread.php?t=24750
Thanks
Fame !
Apr 29, 2009 | Cell Phones
Games Download
How to put games on your samsung
1st - Type in the code *#9998*52824678255#
A message will come up saying activated. Now you are ready to install your java games.
2nd - Download a program called jad maker, because in order to install your java games you need the .jar file and the .jad and most torrents only include the .jar
3rd - Find some compatible java games to download.
You can find many games at: www.getjar.com
4th - Send the .jar and .jad file for the game to your phone, whether via bluetooth or usb cable.
5th - The files will most likely go to your other files folder. Open the .jad and it will install the game for you then ask if you would like to play it.
*Notes*
Each time you turn off your phone you need to re-enter the code.
Some games will simply not work on your phone.
If you would like you can reply with your phone model and list the games that work on that phone
Apr 09, 2009 | Samsung SGH-t629 Cellular Phone
Mobile games
hi u can download the games for ur mobile from the following website named as www.zedge.net...
first u have to register in this website... nothing big to register so dont worry..Just u needed a valid mail id to register in this website and u can start to download games for ur samsung mobile...
thank u.. rate me!!!
Feb 01, 2009 | Samsung SGH-G600 Cellular Phone
Downloading games on samsung sgh e840
http://www.mobilerated.com/samsung-sgh-e840-games.html
basicly you need the software on the pc side and then just transfer them into the phone.
Jun 07, 2008 | Samsung D840 Cellular Phone
Download games
what network are you with ?
May 08, 2008 | Samsung SGH-D820 Cellular Phone
Downloading games by using usb cable
u can not install a java game1.gif that u have placed in your mmc via the usb cable...
but u can put it in the correct directory and folder using FExplorer
when u open FExplorer, go to E: then u will find the jar. file, go to options and select copy.
then go back out and into directory C:/Installs and go to options and select paste
now u can go to appz and u will there will come a message saying u have uninstalled apps on your phone
press gamepad right and select install and thats that
Feb 07, 2008 | Samsung SGH-X700 Cellular Phone
Problems on games in samsung e250
To Install Java Games On Your Samsung-E250,You Have To Download "Softick" PPP and A "Java game Uploader"(search it on Google)..........
lnstall java games using usb data cable
SAMSUNG E250
Install\Run SoftickPPP221 from the Softick.PPP.v2.21 Folder. Ignore any errors about usbsync.dll by pressing OK.
Leave the option use usb in shared mode checked.
Run when finished installing. You will get an error message about being unable to locate usbport.dll, just click cancel.
Plug in your usb cable and turn phone on.
Right click on softickppp running in your taskbar and select settings.
In the usb tab uncheck accept ppp connection on usb and tick both use usb in exclusive mode and overide usb compatability,
Click on ok and completely exit softickppp by right clicking then exit.
Run softickppp and again goto settings. On the bluetooth\serial tab tick the correct com port.Mine is com3. Then click ok
On your phone key in *#52828378# press 2 ota type setting and select serial bearer ota.
Run samsung java uploader and add your jad file
On your phone select 3 serial test , 1 ppp up , 2 usb
Your phone will now reboot. While its rebooting right cklick on softickkppp in your taskbar and choose shutdown ppp
When your phone has rebooted again key in *#52828378#
Right click softickk ppp and activate ppp
On your phones java test menu press 3 serial test , 1 ppp up , 2 usb , 2 serial download
Your game should install and start running.
Oct 15, 2007 | Samsung SGH-E900 Cellular Phone
check whether the java software is being loaded into the mobile
Sep 11, 2007 | Samsung SGH-E900 Cellular Phone
Samsung SGH-E900 Cellular Phone Logo
105 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
