Question about Dryers
Whirlpool dryer my clothes dryer smells like something is burning on the inside of the dryer. we've cleaned the vents out...
Replace the thermostat
Posted on Apr 29, 2008
Replaced bad thermal cutoff on Whirlpool dryer LEC6848an with new kit FSP 279769 (cutoff & t-stat). Also, cleaned duct, vent, chute, etc. Heats now, but had to shut it off after a few seconds due to...
It is common to have a slight burning smell in the dryer immediately following a clean and inspect of the cabinet. Although you may have cleaned the dryer cabinet interior and the ventilation ducting, dust particles often get stirred up and will settle on the heating element. These small particles will eventually burn off and should not create any hazards to the operation of the appliance. Allow to run for a few minutes and monitor. The smell should go away.
Apr 18, 2011 | Whirlpool Dryers
It is taking over 2 hours to dry a load of clothes. I stopped the cycle and opened the door to check the clothes. The dryer smelled like something was burning but no visible smoke. This is a fairly new...
Sounds like the vent is clogged with lint. You should have the vent cleaned once a year to keep the appliance operating properly. Also, make sure there are no kinks in the vent line.
Jan 20, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Burning smell
Stop using the dryer! You are probably close to having a fire if you continue to use it. The whole vent system should be taken apart, cleaned, the heat limit sensors checked and the duct cleaned. Your dryer is overheating and is a danger.
Aug 11, 2009 | Dryers
Dryer shutting off too early. Faint smell of something burning?
Check the vent for clogging condition that will turn off unit and cause it to overheat. If vent goes up to roof check up there also - that is where mine was clogged with a sort of paper mache clog!!!!!
Sep 02, 2017 | Whirlpool LER4634J Electric Dryer
I run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
Brand new Whirlpool Duet Sport gas dryer & burning plastic smell
I would consult the place of purchase. If they do not stand behind the product, then get the manufacturers support #. They will stand behind their product, especially if it is a possible fire hazard. THe smell you are smelling could be anything, but without being there and taking off the cover and doing a visual check. it's hard to dianose. It is possible that something that is plastic has fallen out of a pocket and gotten inside the unit while it was drying clothes and fallen onto the igniter housing.
Nov 18, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
When the clothes are drying you can smell something burning and the clothes smell burt when they are done. Coleman
You may have a venting issue. Check your lint filter and venting system. Excess lint builds up and goes onto the element and burns off. This can be dangerous and a fire hazard. Clean your vents, even open up the dryer and vaccum it out too.
Sgt 48
Jun 03, 2008 | Whirlpool Dryers
Dryers Logo
244 people viewed this question
Top Dryers Experts
