Question about Refrigerators
Kitchen Aid Superba, Model KSRS271, Freezer is defrosting
  • 1 more comment
  • kellie_kozon Sep 24, 2009
    Totally defrosted, actually hot inside (freezer and refrigerator.) Light still works, fan is blowing, but it's all hot air.
  • jason king
    jason king May 11, 2010
    is the compressor in the back running ?
  • jason king
    yes they do a defrost cycle, or is it totally defrosted ?
  • 42 Answers
SOURCE: Kitchen Aid Superba
To the person who hears a clicking sound you are correct, the compressor is trying to start but is not starting and that causes the overload to trip (click) wait a short time and it all happens again. Either the start relay is bad or the compressor is locked up. Less than 1 year old should be in warranty. If you want to try to check the relay you will need to unplug it from the side of the compressor. Once removed try to shake it and if you hear a rattle noise the relay is bad. To test the compressor you would need a test tool or be very experienced to perform accurate test.
Posted on Nov 22, 2007
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Posted on Sep 16, 2008
SOURCE: Kitchen aid -Superba 42,
The rubber door gaskets tend to crease often times causing the cold air to escape. If your door gaskets are OK it's time to call the repair man!
Posted on Apr 08, 2009
  • 744 Answers
SOURCE: Problem with Kitchen Aid side by Side
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: defrost stat heaters evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
Posted on Jul 11, 2009
Kitchen aid superba ksra22fkss00 refrigerator. Freezer temp too low. All diagnostics checks good. What could the problem?
Possibly defrost problem or evaporator fan in freezer or condenser fan at compressor. If none of those, probably a sealed system problem
Aug 31, 2017 | Refrigerators
My Kitchen Aid Superba refrigerator Model # KSRS25FGWH01 stopped working. no fans come on no noise only fridge lights. working the other day but fridge was not cold enough freezer was fine now nothing
The machine goes into the defrost mode every day or two. During defrost mode you will see these symptoms. After an hour or two, it should return to normal. If not, the defrost timer may be stuck in the defrost position.
Mar 05, 2017 | Refrigerators
Kitchenaid superba ksrg25fkwh01 wire harness
Called Kitchen aid and protested, frig was 4 years old at the time. door was almost $1200 to replace. Kitchen aid paid for new door and installation
Sep 19, 2012 | KitchenAid Superba Architect KSCS25INSS...
Ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Jun 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Make sure the fan motor is running in the freezer.
Sep 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Superba Model KSRS22D
The Kitchenaid Superba KSRS22D has 14.4 cu.ft. refrigerator space and 7.1 cu.ft. freezer space for a total of 21.5 cu.ft. Hope this helps... -Syren
Jul 02, 2008 | Refrigerators
Kitchen Aid Superba...freezer shuts off..
sounds like your defrost drain is frozen or blocked its in the freezer side under the back panel beneath the evaprator
Jun 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
277 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
