Question about Whirlpool Washing Machines
It keeps flashing f 05 - Whirlpool Washing Machines
  • 725 Answers
An F05 is a water temperature sensor error.
You will need to check the
1 Water Temperature Sensor
2 Heating Element
3 Heating Element Relay on control
let me know if you want too check it..
Posted on Sep 24, 2009
I have an err 05 with my Canon 7D
The err code 05 says the same, Flash could not pop up. The manual says, switch off the camera and switch on again.it could be this does not change anything. Just a little more chance, when you switch off the camera and remove the battery. And while it is out, just charge the battery. When you replace the battery and the error reoccurs best guess you have to visit the Canon service centre.
Make sure there is no mechanical obstruction, that keeps the flash from popping up.
Jan 05, 2014 | Canon EOS 7D Digital Camera
Error 05 flash doesn't pop up
spray a very very small amount of WD40 on the hings of pop up flash (use the thin RED spray tube)
Nov 17, 2012 | Canon EOS 400D / Rebel XTi Digital Camera
Canon eos 350d error 05, keep switchin on and off to correct but keeps reoccuring
is it also trying to release the flash when this happens? If so try and manoeuvre the flash a little by hand as it try's to open. once it opens its usually fine thereafter.
May 04, 2011 | Canon Rebel XT / EOS 350D Digital Camera
05 altima blows fuse for left headlight
Go out at night, or dusk, with a flash lite, replace the fuse with a higher amp or any spare fuse, turn out the lights, turn on the car lights, look for a spark somewhere, have people standing around engine comp, if it doesn't blow, wiggle wires, if it shorts out, you should see a spark, fix with tape, you should be all set.
Dec 29, 2009 | 2003 Nissan Altima
My 05 subaru outback's odometer keeps flashing .ill.3 and ill.4 what does it mean
ILLUMINATION is set at 3 or 4 (the dimmer/brighter switch on the dash lights) Mine was flashing and dimmer switch had to be replaced.
Dec 12, 2009 | 2005 Subaru Outback
I can't load quick book 05' I keep getting the same error.
- close all programs
- use internet explorer to open http://www.adobe.com/products/flashplayer/ - download and install flash player.
- run quick book 05 installation again
Mar 22, 2009 | Intuit QuickBooks: Pro 2005 for PC
HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Keep getting err 05 stating that the flash is obstructed
does the flash pop up?
Try this in a dark room with the setting on automatic.
If it does NOT pop up, the problem is that the flash is stuck in some way. Try gently prying it up if you can. if not, take it into a camera repair shop to get it fixed.
Nov 18, 2008 | Canon EOS 40D Digital Camera
Err 05
In my case, I borrowed a camera and when I got it back, err 05 appears. I've located a bit of old orange juice which sticked one of the sensors - you can see the sensors when flash is popped out.
Feb 19, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Rebel XT error 05
I had the same err 05 problem on my canon 350d. But there was no need to remove or open anything! If you have the camera in front of you looking at the lens, you can see a tiny black switch hidden under the flash. On the right side where the flash is attached to the body you can find a fine black piece of plastic sticking out of the camera body (smaller than 2mm. This switch can easily get stuck with some dust (or a grain of sand in my case)
Carefully clean it (with an ear stick) so it can go up down again as the flash goes open or is closed. (It somehow serves as a mechanical sensor)
This solved my error 05. Remember that this is just a general Flash error indication and there could be another problem triggering the warning.
Sep 15, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Washing Machines Logo
42 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
