Question about Panasonic CT-34WX15 34" TV
I have a Panasonic TV Model number CT-34WX15N. When I turn on the power switch i acts like it is coming on, I hear relays clicking, but it switches off and the front LED flashes 5 times. I determined through a search that this indicates a problem with the IC 4011. How do I identify which chip needs replacing? Is there more than one 4011 chip in this TV? And what exactly is the function of the chip? I plan on fixing this myself hopefully, but I have limited knowledge of TV's. Thanks in advance.
Orbixx
  • 133 Answers
SOURCE: panasonic ct-36hl43 tv
This is usually down to a safety feature cutting out the Television from harming itself. Or quite possibly a fault that make it turn itself off - it may well be thinking it's receiving the command to turn itself off. Either way, it's impossible to find out without opening it up. A professional repair is the only way, check up on your warranty. You may want to plug it into a different power source, just on the off-chance that it may solve your problem - but don't get your hopes up.
Posted on Sep 07, 2007
  • 93 Answers
SOURCE: panasonic tv ct-32hxc14j
try to reheat or resolder your tv.
Posted on Oct 23, 2007
  • 2318 Answers
SOURCE: Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Posted on Jan 16, 2008
SOURCE: panasonic CT-32SL14 flat screen tv stopped working
We played Wii sports and fit for few hours than tv started to flicker and change colors to green and black and white. We shut down Wii and not TV screen doesn't show any picture. The power is there and the sound... but the screen is just blue. Any one experienced anything similar?
Posted on Jul 05, 2008
jeffreyirish
  • 7 Answers
SOURCE: TV on getting switched on
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side on the bottom, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Posted on Jun 18, 2009
Panasonic color TV model CT-32G9J won't turn on.
been a long time since fixed an crt tv. but if you have a stand by light the problem on this model is the control chip if remember right it sits on the left side near to the front. think its an 8 pin chip. these just go and it will not turn on. these chips are easy to get hold of and are cheap. you just need to remove it and replace with a new one. and the tv will work again. its not on the power board but is controlling the power start up. if there is no stand by light its a longer problem to solve. it could be a number of problems. would need to know if any problems happened before the tv did not turn on.
Jan 15, 2014 | Televison & Video
I have a panosoinic tv model CT-2013SA and my son typed in a parental code and forgot it
Hello
There is a way to unlock Panasonic TVs. It will work on most of the Panasonic sets. Just try it.
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, that is, switch on the set by its front panel power switch, and put it off by remote hanset, [standby position], then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip.
OK.
Feb 12, 2011 | Panasonic CT-20G6 20" TV
The TV will not power on at all
Is the set completely dead? if so you should see no indicator lights and hear no "click' when the power button is pressed. If so than the only thing wrong with the set ic the main Fuse (6.3A 250VAC) has blown.
Sep 19, 2009 | Panasonic CT-32HC14 32" TV
Panasonic CT-36HX42F I turn it on and then, turns off
It seems that the electrical relay's, it getting completed is not able to create the high voltage required for proper display. Hence on switching it on, the power LED will immediately light up but since the circuit is not completed it switches to standby and then off. Get the relays replaced and make sure you connect the main power chord to a 15 Ampere rating wiring usually the line meant for A/c and hot water Geyser(called as high power line)..........sodeep
Sep 19, 2009 | Panasonic CT-32HX42 32" TV
Panasonic CT32SF wont turn on
Dont know spec of this model but if it has a CRT (glass tube) display rather than a LCD one, clicking at switch on is idicative of a power supply overload which, 99 times out of a hundred on a CRT telly is down to a fault in the power supply itself or the line output stage (the bit that generates the very high voltages in CRT tellys and also makes the picture scan left to right).
In short, not a DIY fix - take it to a repair shop.
Sep 07, 2009 | Panasonic CT-32SL14 32" TV
Tv shuts off tv/video doesnt work
that is a indication that a fault is about to occur, dont force that tv take it to a technician before it switches off completely, a power supply is supposed to be checked.
Mar 26, 2009 | Panasonic CT-36SL13 32" TV
Panasonic TX14S2T
What are the symptoms? Is the set dead? Please clarify
model number from back of set...The red power light coming on means the AC fuse is OK, but the B+ fuse may be bad. If that
is true,check the horiz o/p xistor and get back to me....T.
Oct 20, 2007 | Panasonic CT-27G14 27" TV
Wont turn on
Hello zang,
This denotes a problem with the switching power supply or the high voltage power supply. what is happening is the safety relay is being actuated by the shutdown circuit. Any number of things can cause this proble but more then likely the problem is in the high voltage power supply section and or its associative circuitry. The switching power supply and the high voltages power supply have very dangerous voltages and I would not suggest that you work on the TV set unless you do have a background in electronics. If you do not I would suggest that you take the TV set to an electronics shop for repairs. If you do have a background in electronics, you will need the following items:
1) A schematic diagram (to know where voltage and signal test points are located and to have a reference of the levels.
2) A multimeter (to measure the DC voltage levels on the TV Set)
3) An oscilloscope (to measuer the AC voltage and signal levels in the TV set and compair them to the values in the schematic)
4) A signal generator (to generate a reference signal for troubleshooting)
I hope this helps,
Shuttle83
Oct 11, 2007 | Panasonic CT-32HX41 32" TV
CT-32HL42 Panasonic will not turn on
These sets have a number of problems like yours which are associated with bad solder connections or cold solder joints. On this set one pin on the the start-up relay is usually open or intermittent The solution is to resolder connections on main p.c board. and especially on the vertical output IC. Also change the caps in the vertical section to avoid future problems. Scrivitron.
Jul 06, 2007 | Panasonic CT-27G13 TV
Panasonic CT-34WX15 34" TV Logo
144 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
