Question about Mitsubishi WT-46807 46" Rear Projection Television
Won't stay on for more than a few seconds
I tried the menu/input button thing. I get two blinks, pause, two blinks, then a long pause.
  • SD Tech
    SD Tech May 11, 2010
    this is error code for short protection--usually it means one or both of the fuses that protect the convergence circuit are blown---you would need to change the fuse or fuses and both convergence chips---let me know if you need advice or information about this.
  • Mitsubishi Master
  • 5,138 Answers
Replace Both of your STK ICs big black ICs will have # on them for example STK392-570 Call Mats for Parts 1-800-628-1118
Posted on Sep 24, 2009
Turns itself off and then won't stay on
Do the self check.
If you unplugged the set, plug it back, turn it on and allow to fail.
Press both the Menu and Input (input may be labeled device) buttons on the front of the set and Hold both for at least 5 seconds and release both.
Power light will begin to blink a two digit error code like 2 blinks, 2 blinks, pause and repeat it for a total of 5 times.
Let me know what error you find and I tell you the meaning and a possible answer.
Dec 21, 2012 | Mitsubishi WS-65807 65" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Won't turn on
If power light comes on for a few seconds and goes off: on front of set press and hold both the Menu and input buttons for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Please let me know what error code you find and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65511 65" Rear Projection...
My tv won't stay on.I pressed reset and input at same time.it blinks twice and that's it.
You have to press the menu button and the input buttons both in together and hold for 6 seconds then count the two digit blink code and let me know the blink sequence.
Jun 17, 2011 | Mitsubishi WS-65809 65" Rear Projection...
It won't turn on and we don't have a remote control. What can we do ? Mitsubishi Medallion HD 1080
not knowing model number I will suggest a few things: if green power light comes on for a few seconds and goes out:
On front of set press and hold both the Menu and Input (device) buttons at same time for at least 5 seconds and release both.
Power light should blink a two digit error code like 2 blinks,,2 blinks,, a pause and repeat it several times.
This is a error code that indicates what area problem is in, let me know what error code you find and I will tell you what it means----if set has been unplugged you will have to try to turn it on and let it fail before you go for the error code.
SD TECH
Mar 31, 2011 | Mitsubishi Televison & Video
TV won"t stay on turns off in 3 seconds WS 55807
Do the self check when power light goes off.
On front of set press and hold both the menu and input buttons for 5 seconds or longer and release both buttons.
Power light will blink a error code like: 2 blinks, 2 blinks, a pause and repeat about 4 more times.
Let me know what error code you find and I will tell you what it means.
If this information told you something rate this solution as very helpful as I do this here for free.
SD TECH
Aug 28, 2010 | Mitsubishi WS-55807 TV
Can't get tv to stay on
If power light comes on and then goes off in a few seconds:
On front of set press and hold both the Menu and Input buttons at same time for at least 5 seconds and release both.
Power light will blink a two digit error code: most common is 2 blinks, 2 blinks, a pause and then it repeats it 4 more times.
Let me know what error code you get and I will tell what it means.
If this information told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 28, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Will not stay on., Automatically turns off.
Try pressing in both the menu and device/input buttons in together on the front of the set and hold for 5 seconds to see if the led will blink a two digit error code such as 2 blinks then a pause then two more blinks followed by a pause which would indicate a 22 error. Then let me know what the blink code was if any.
May 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-55908 Rear Projection. Doesen't Stay on.
have you tried to access the self diagnosis feature by holding the menu and device/input buttons on the set both in together for five seconds to see if the led will blink a two digit code such as two blinks pause two blinks for a 22 error? Try that and let me know the blink code and i can assist you.
May 21, 2009 | Televison & Video
Turn on the TV and only Timer light is on , no sound & picture
press the menu and input/device buttons both in together on the front of the set and hold for 5 seconds and then see if the set blinks a number of blink pauses and then blinks another number such as 2 blink pause 2 blinks which would be a 22 caode. It then repeats that code.
Jan 21, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
