Question about Insignia IS 20" TV040919 TV
Tv turns off by itself
I go to turn on my Insignia tv. You can hear from the static sound it turns on but it then turns itself off after about 5 seconds.
  • trevorsmommy Dec 16, 2007
    Oh yeah, the above tv is an IS-TVDVD20.
  • Anonymous Dec 16, 2007
    OFF BRAND 27" TV. SHUTS DOWN AND COMES BACK ON REPEATEDLY. aLSO RUNS THROUGH CHANNELS IN CHANNEL SEARCH. LOVE TO KNOW WHY. IT'S REFURBISHED THANKS
Try unplugging the cord for a few seconds and then plug back in. This happens on one of our TVs. Using this procedure takes care of the problem. It is like something needs to be reset.
Posted on Jan 08, 2008
50" Insignia plasma made a pop sound
This might require attention by a qualified service technician.
Jul 12, 2012 | Televison & Video
I put banana clips on the wires and plugged them into the Insignia 200w audio receiver and everything sounds static tv and music
For temporary just for testing it ok.. but using banana clips permanently it not a good idear because due to excesive sound vibration it will create static for sure to avoid that you may have to souldering those wired in place to avoid that static and causing eventual damage inside your receiver... any conection as to be well connected special went it time to connect a large amps., beside a turn table, you may look for a good ground.... I suggest to put a solid ground wire also betwen your tv set and your receiver
for eventual hi static discharge., also make sure use a power bar for more protection ...good luck
Oct 15, 2010 | Insignia 200W Stereo Receiver
I have an Insignia 32'' lcd tv. I shut it off by
when you got off the couch to turn of your set you gave it a static charge which corrupted the CPU try unpluging unit for 30 seconds see it that fixes your problem if not you will need a main board
Nov 18, 2009 | Insignia IS-LCDTV32 32 in. Television
Box was working, tv now back to analog
Sounds like the converter didn't make it. The symptoms you describe sound like the converter was working and then died. You may want to bring it back to store were you got it.
Jun 18, 2009 | Insignia Digital-to-Analog Converter for...
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
No sound on my 32'' Insignia LCD HDTV
Try to unplug the tv for a few seconds and then plug it back in again.
Jan 28, 2009 | Insignia LCDTV26 26 in. Television
Insignia PC speakers - give a weird static feedback noise
I'm going to vote for the haunted option.
Sound like you have some noise on your power lines. This can be caused from many different things. Normaly it is a motor going bad or a compressor starting up. From the AC unit or refrigerator.
See if you can correspond the noise to anything else happening in the house. Fridge starting up, AC or heat cycling on...etc.
It may be that you just have speakers and a cordless phone going bad at the same time.
It might just be Casper the friendly ghost playing tricks... ha!
Jan 23, 2009 | Insignia 2.0 Speaker System (2-Piece)
Turns off between 1 hour and 5 hours
sounds defective, but try the Insignia help line, in case you've accidentally got it on a timer setting:  Call 877-467-4289
May 12, 2008 | Insignia LCDTV26 26 in. Television
Sound and Volume trouble
I bought my Insignia 32" LCD in November 2007 - same problem. I figured out that if you press the "input" button on your remote select any of the other options "component 1, composite 1, etc.. that you're TV isn't on -then press "input" again and go back to the component that you're TV plays on - you'll have volume when you go back every time. I've gotten so used to doing it now that it's become habit. 9 times out of 10 I have to do it.
Mar 15, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia IS 20" TV040919 TV Logo
661 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
