Question about Refrigerators
Frigidaire side by side not cooling at all... condensor fan and compressor both running, coils clean, evap fan running, cold control turns unit off and on, defrost timer was replaced, no frosted evap coils..?????????HELP.....NEED STEP BY STEP INSTRUCTIONS FOR TROUBLESHOOTING....PLEASE....THANKS,,,Also have a Kenmore freezer doing same thing...pressures on the freezer are: low side -10(vac) high side 100psi
  • roger_bri797
    roger_bri797 Sep 25, 2009
    THANK YOU !! I have been trying for a week to get that info..Thank You...
  • 358 Answers
First I will check the pressures , should be 25 low side and 140 high for freon 134a ,but if you have the same pressures in both sides , the compressor is not pumpping and has to be replaced,and if there is negative pressure in the low side and over 180 or more on the high side ,there must be a restriction in the filter dryer or in the capilar tube,in this case replace the dryer , vacumm the system for about 45 minutes and recharge the unit with the rigth amount of freon in oz. using an scale.But if still is restricted you have to replace the capilar tube and also the filter dryer and repit the vacum and charging process.
Posted on Sep 24, 2009
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
Low pressure on suction side and no cooling
If your running 134 a your short of gas
if your running 404a your short of gas
check the super heat it should be 5 ktd
Jan 10, 2014 | True TMC-58-DS Commercial Refrigerator
True gdm 26 no longer cooling. Internal tem 80 degrees, Condensor fans running, Coil is not showing any frost or icing. Removed cover and cleaned coil and removed dust and dirt. Went out "all of a...
sounds like the compressor is not running. The condenser fans are located at the compressor. The fans in the conditioned space are the evap fans. A refrig usually does not have any device controlling the evap fans, they are to run 24/7. Freezers have other controls. Start there and let me know if I can help further.
Nov 20, 2010 | True GDM-26 Refrigerator
Kenmore refrigerator 598586 intermittent cooling. when not cooling only condensor fan runs. evap motor has been replaced by service company same problem. thanks
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 16, 2010 | Kenmore 58522 Side by Side Refrigerator
Frigidaire Side By Side Not Cooling
That sounds like the start relay is buzzing. Unplug and lets check the compressor to see how hot and if too hot to hold your hand on the top of compressor we need to leave it unplugged until we find out if the start relay, start capacitor, overload or if the condenser fan stops after running a short while. Sea Breeze
Sep 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
Upright freezer quit cooling, interior fan runs, compressor runs
The coils are most certainly there probably located under your unit. Clean them thoroughly. Look under and to the very top of that space.
Jul 08, 2009 | Kenmore 50522 / 50524 Side by Side...
Refrigeration
Your pressure sound pretty good. I would check the thermostat and the relay on the compressor. If you are getting no frost on your coil, that is usually a tall-tall sign of a bad compressor then it would be better to just replace the unit.
Apr 22, 2009 | Frigidaire FRT21H8 Top Freezer...
GE PSC23NSD SS refrigerator malfunction
Check the cover in back of the freezer for for frost build-up. I think Frost reached the evap fan-blades and stopped it from blowing cold to the ref-side. Contro;s can be confusing. The ON-OFF controls how long the compressor runs, and the other dial how open or choked the airflow from the freezer into the refrigerator. Sometimes it happens that you have that flapper shut and no air is getting moved to the reefer. If frost is on the cover you have dead heater elements on the evap coils or a faulty hi-temp limit switch, which is the disc thingee at the top of the coils. A bad timer also may disallow it going into defrost - think about it. Chris in big bEar
Apr 20, 2009 | GE GSL22JFPBS Side by Side Refrigerator
Frigidaire FRS23H5AS side by side. condensor fan runs, no voltage to compressor
i replaced the control-defrost adaptive timer pc board after lighting storm and it worked fine for ten days then i turn off may power to my house to reground the house and my frig is doing the same thing fan not running evap freezing fan not running what is going on
Apr 08, 2008 | Frigidaire FRS23H5AS Side by Side...
Refrigerator cools, but no freezer fan & no condensor fan running
Check the back of you fridge and make sure the coils are clean. If you have access to a small air compressor, blow everything out and make sure the motor are is clean. The build up of dirt on the coils will not let the heat escape during the cooling process.
Mar 04, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
