Question about Kenmore 24032\24036 Top Load Washer
Large amounts of lint deposited on laundry
Large amounts of lint are present on the wet laundry after the load has run. Is there a filter that needs to be cleaned?
  • 15,935 Answers
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
HW5513M Hoover washer dryer has a coin filter which I clean regularly, but washer door seal (and hence laundry) has wet fluff buildup. How do I prevent this?
There should be a lint filter somewhere in the dryer. Even with a lint filter you are likely to get accumulation around the door seal.
Aug 14, 2016 | Hoover Washing Machines
How do you wire the dryer MDE300AYW
Instructions
    • 1 Remove the lint screen from the dryer. If you are unsure how to remove the lint trap, refer to your owner's manual, as removal directions vary among Maytag models.
    • 2 Use your fingers to remove large chunks of lint from the lint screen. You should remove the lint from the lint trap after every load.
    • 3 Run the lint screen under the faucet. Use hot water and thoroughly wet down both sides.
    • 4 Scrub both sides of the lint screen with a wet nylon scrub brush. Rinse the screen again under hot water to remove loosened buildup. Allow the lint screen to air-dry on a towel before putting it back inside of the dryer.
    • 5 Make a paste of powdered laundry soap and warm water into a small bowl. Use three parts powdered detergent to one part water. Stir with a spoon until a paste forms.
    • 6 Dip a soft rag into the paste. Wipe down the entire interior of the dirty Maytag dryer with the rag and paste. Apply more paste to the cloth as needed.
    • 7 Rinse the interior of the dryer with a damp rag to remove the paste.
    • 8 Dry a load of damp towels in the Maytag dryer. Run a complete dry cycle to remove any residue left inside.
    • 9 Wipe down the exterior of the dryer with a rag moistened with all-purpose household cleaner. You can also use the household cleaner to remove certain stains from the interior of the dryer. Make sure the cleaner you are using is noninflammable.
Jan 15, 2013 | Maytag Dryers
It's a whirlpool awz 7466. It runs fine, but I do not know which settings it needs to be on to dry my clothes normally. A small load will take at least 2 hours and makes laundry take forever. Any help
Hi Jennifer,
Two hours to dry a small load of laundry (even a large load for that matter) is way too long. You're wasting electricity too. The first thing you should do is consult the manual for the dryer to be sure you've selected the proper setting. The literature for this can be found here.
Consult this literature page 63 for the location and cleaning instructions for the (e) lint filter after each drying cycle and (h) heat exchanger at least monthly. Failure to clean both will result in long drying times. If you have the "Gentle" cycle selected, drying time will be prolonged, too.
Hopefully, these suggestions will help you solve the problem. Good luck!
Jan 07, 2013 | Dryers
Spin cycle leaves clothes wet
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Jun 17, 2010 | LG DLG7188 Gas Dryer
Not enough heat
You may need to adjust the air flow on your dryer vent.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
Solution:
LG DRYER SERVICE MANUAL
LG PARTS
May 11, 2010 | LG DLG5988 Stainless Steel Gas Dryer
We just cleaned out the filter as there were F02 error and a bad sulpher smell with each load. A pen, a laundry soap sheet and a load of lint was clogging everythign.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
Jan 30, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Red light on,check filter
Is this a ventless dryer? I.e. a condensing dryer?
If so, there is a filter that filters the lint out of the water in the condensing unit. Check your owner's manual to find out how to service this. It is usually a little door on the front, bottom of the unit.
If it is not a ventless dryer, then the only filter I know is the lint screen.
Good Luck!
Oct 10, 2009 | LG WM-3677HW Front Load Washer / Dryer
My dryer runs but there is no heat to dry the clothes.
any heat at all? clogged vent pipe number one issue(if some heat is present) check 220 rec for 220! could be bad breaker motor will turn on 110 but needs 220 for heat....then go for element
Mar 13, 2009 | Dryers
I put laundry soap in the dryer by accident
DO NOT pour water down the lint filter of a dryer! This could have catastrophic results. There are live voltages present in a dryer even with the power shut off. You have a blower fan and a motor in the air baffle. Pouring water in there will definitely damage something (if the soap hasn't already). Detergent is a corrosive and will damage anything electrical and any painted surface if left too long. I hate to say it, but you must open the dryer up and remove the air baffle and clean it out thoroughly. Unplug the machine before you attempt. You need to wipe up all the soap residue with rags. You will need to let me know if the dryer has a lint filter on the top of the machine, or in the door before I can suggest how to disassemble. This will make a big difference in the amount of effort required to correct this. Post me back with the info...
Aug 08, 2007 | Kenmore 60172 Electric Commercial Dryer
Kenmore 24032\24036 Top Load Washer Logo
49 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
