Question about GE Microwave Ovens
How do i remove build in micowave from top stove ?
  • 333 Answers
On the cabinet above the microwave there will be two screws. Hold the microwave with one hand while unscrewing the screws with the other. Once the screws are removed, the microwave will lean forward but not come off the wall. Once you have a good grip on the microwave, lift up towards the back of the microwave and it will come away from the wall.
Posted on Sep 24, 2009
Micowave just stopped working
The main fuse in the microwave oven has blown, this is often caused by one or two door switches going bad usually the result of food partical build up and must be replaced to fix the problem.
Mar 18, 2012 | Sunbeam Microwave Ovens
I have a white GoldStar Micowave the is mounted to the wall above my stove, Model # MV1526W. I need a front top vent cover for it. I am looking for the cheapest costing web site I can order on line. I...
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Apr 03, 2011 | Microwave Ovens
How do i ermove the oven from the wall (get to the back installation hardware)?
There should be Two very large screws that secure it from the top. These will be in the cabinets above the micowave.
Be very carefull when removing these, the unit will be heavy.
I hope this helps.
asnowman
Mar 05, 2011 | Sharp R-1610 Microwave Oven
Trying to change a fuse in ge microwave oven je2160. however, we can't determine how to find the old fuse and remove the cover
THE FUSE IS ON THE RIGHT HAND SIDE OF THE MICOWAVE AS YOU LOOK AT IT JUST AT THE TOP BEHIND THE CLOCK
Dec 25, 2010 | GE JE2160 Microwave Oven
GETTING A NEW STOVE THE OLD ONE HAS UPPER MICROWAVE ATTACHED W/ FAN UNDER IT LANDLORD SAYS ITS NOT MANDATORY TO HAVE A FAN IF YOU HAVE AN ELECTRIC STOVE. I THINK THEY ARE JUST CUTTING CORNERS? PLEASE REPLY...
Codes vary from district to district.
Contact your local building department for range hood codes in your area.
Code or not,range hoods are great for removing cooking fumes.
Sep 22, 2010 | Microwave Ovens
Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Jan 19, 2010 | Panasonic Microwave Ovens
How to install a electric line for over stove micowave
This is usually best left to a licensed electrician, however in some homes there is already electrical wiring over the stove for an exhaust fan. You might be able to tap into the exhaust fan wiring and install an outlet that you can plug the microwave into, or if there is an electrical outlet near the stove area you might can tap into it just be sure that you are not overloading the outlet. For example if there is a refrigerator or other major appliance using power from this outlet it might not carry enough current to operate the refrigerator and the microwave at the same time and will cause the circuit breaker to open or fuses to blow.
Sep 09, 2009 | Kenmore Microwave Ovens
Remove over the stove microwave Sharp R-1462
Ther are 2 long screws at the top on the left and right side in the cabinet.Remove them carefully it is heavy and will drop hard if you do not hold it while you remove them.If it does not come off then there maybe a release handle on the top left part of the vent you must look carfully hope that helped:)
May 18, 2009 | Microwave Ovens
Kenmore micowave oven interior light
THe microwave has to be removed from the wall and then the outer cabinet has to be removed to get to the bulb. Do not do this with the unit plugged in and do not do this if u don't know how to work on a microwave as there is a shock hazard.
Jan 26, 2009 | Kenmore Microwave Ovens
My micowave oven purchased 12-15-07 from Lowe's. The exuast fan will not come on, I press the touch pad key and it reads low and when I touch it again it reads high but the fan does not run.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
GE Customer Service is here.
(Just for the sake of discussion, have the stove top lights gone out recently? Quite often they will short, causing fan or light trouble.)
Aug 03, 2008 | GE Microwave Ovens
Microwave Ovens Logo
49 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
