Question about Dell Audio Players & Recorders
Emachine speakers and dell motherboard
How do I plug in my Emachine's speakers into my dell tower?
Did you find out how to make it work?? I'm having the same issue!
Posted on Nov 21, 2009
Emachine w3629 pc
The green audio jack is for speaker output. If you are running the realtek audio software as part of the driver pack then you might also need to assign you speakers to the jack in the software.
Oct 31, 2017 | Computers & Internet
What is the motherboard in a eMachine 1651-02w?
Ronald,
I was able to find some information about your e-machine. Please click on the link below and scroll down to motherboard section to find the motherboard type.
http://www.skyline-eng.com/index.cfm?fuseaction=category.display&category_id=7768
This was the only to get that info since i don't have this machine. I hope this helps!!!.
Regards,
Anish
Dec 30, 2012 | eMachines ET1641-02w (PT.NA60X.001) PC...
How do i hookup logitech speakers #z313 to my emachine e202hl
The manual for your speakers can be found at http://www.logitech.com/repository/1411/pdf/27251.1.0.pdf. The Speakers should be conected to your computer as opposed to the moniter. Disconect the small wire from the moniter to the computer and insert the plug from the speakers where it came from.
Nov 14, 2012 | E-Machines Computers & Internet
Plugged in my emachine LE1938 to my dell without the DVI cable, screen displays 'no signal'. Shouldn't the monitor work without the DVI cable?
The DVI cable transports the display signal from the video card to the monitor.
I think what Ron is asking is if you used a different cable to connect the monitor to the computer. (I'm assuming you used an old 15 pin monitor cable or whatever those old cables were?)
Without getting into your BIOS:
So on your computer, you probably have an onboard video card (a video card built into the motherboard itself), and a dedicated video card (probably where you're seeing the DVI out).
It may be possible that you have the on board video card (with the traditional connection) disabled, when the dedicated video card is plugged in.
This isn't rocket science, so don't worry. Phillips head screwdriver is all you need.
Pull the side panel off your computer (assuming it's a tower... if not, it's the top panel). Once you have it off, you'll see that video card plugged into a slot on the motherboard, with 1 phillips head screw holding it in place (inside, near the back, where the DVI port is).
Pull the screw, and the video card should come out. From there, the BIOS should recognize your card is missing, and thus revert to using the onboard video card.
Sep 02, 2012 | eMachines E-machines flat screen CRT 17"...
Would emachine speakers be compatible to an acer aspire tower?
Any computer speakers should be compatible with any modern computer provided they use the standard 3.5mm jack (This is the same jack as common headphones for ipod or similar devices).
Feb 19, 2011 | E-Machines eMachines Desktop PC
My Sister has a dell monitor and a emachines tower, She cant get the monitor to turn on. is it compatible? Or is there something else she should try cause she has it hooked up right.
They are compatible, make sure your connectors are right... If the emachine is using a graphics card, make sure it is hooked up to the greaphics card not the motherboard but if you do have it hooked up to the graphics card, then try the motherboard's video output.
Feb 23, 2010 | E-Machines eMachines Monitor E15T4
There is no toggle/powerbutton on the face of the tower
If this is atx power it should be just push to on button look for something that can be depress. On motherboard connection follow motherboard manual. It should be on a header. Together with the reset, power led light, hd LED and the power itself.
Apr 18, 2009 | Computers & Internet
Tower won't turn on
hi try to put the monitor lead in the tower, the leads are both the same, the fuse might be out in the tower lead.
Mar 28, 2009 | E-Machines eMachines Desktop PC
Motherboard sound and old speakers
what really matters is the quality of the usb speakers. check specifications such as wattage first and find reviews if possible. however usb speakers will probably not come close to separate speakers. i'd recommend buying a cheap sound card ($20 or so). these work great overall. $20 spent on a sound card will be a better trade off than $20 spent on speakers. just use your old speakers with the new sound card and you'll have plenty of power. after this i'd recommend headphones as they work great in this case. finally moving the sound card would probably work fine, but i have doubts.
hopefully that helped
Dec 30, 2007 | Dell - 0089D Sound Card
Speakers
There should be a pink / green coloured ports that let you connect your speakers. Some desktops have it right in the front and some behind the tower. Plug it in there.. should work.
- Ranjit
ranjit@supportminds.com
Oct 27, 2007 | Computers & Internet
130 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
