Question about Samsung Eternity Cell Phone
Phone shuts off unexpectedly.. when i make a call, it stays on for about 10 seconds. when i leave it alone, it just turns off then on then off constantly. when i try to open text messages, all it says is initializing.
Toughbook shuts down unexpectedly
how long does it approximately stay "awake" , try to figure out the amount of time for which it stays on before it shuts down , i mean is it right after the OS boot , or a while after , this kindof details may help
Jan 30, 2013 | Panasonic Toughbook Computers & Internet
I just put a new steering column in my 200 saturn sl2 because my ignition lock was messed up. Now when whe try to start the car, it will start up but immediately shut off and then the security light...
Hello: Will try to give you instructions: Attempt to start car, leave key on (security light flashing) let set for 10 minutes, After 10 minutes security light out. Turn key off for ten seconds, turn key on, let set for 10 minutes, turn key off for 10 seconds. turn key back on let set 10 minutes, turn key off for ten seconds, the engine should now start and stay running.
Jan 14, 2011 | Saturn SL2 Cars & Trucks
Error message turn off... Sometimes i have to leave it alone for a day. But still there is a problem.
it most likely needs to be re flowed and cleaned and new cpu compound they i have had them shut off because of getting to hot some times they will only stay on for 10 seconds or so.
Mar 30, 2010 | Nintendo DSi Black Console
I start the iphone and the apple just stays and the loading icon comes...the phone wont turn off manualy but shuts off periodically and comes back on....can anyone help me with this?????
Turn iphone off. Power on holding power and home at same time for 10 seconds, then release power button but hold home for another 30 seconds. Screen will stay blank but should be in DFU recovery mode. Plug into iTunes and recover.
Nov 03, 2009 | Apple iPhone 3G
My iphone 2g only shows the apple for 10 seconds then shuts down
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
After this you'll need to jailbreak it too....
Sep 04, 2009 | Apple iPhone Smartphone
The anti theft system light stays when i drive my 2005 chevy malibu classic
Folllow these steps:
turn ignition to "ON" (dont start the car)
leave it open for 10 minutes.
Turn ignition to "OFF" wait two seconds and turn it back to "ON"
leave it ope for 10 minutes.
Turn it on, start the car normally and have a safe trip. Your system has just relearnt the security passkey.
Good luck.
Jul 08, 2009 | 2005 Chevrolet Malibu
A 1979 Colman RV furnace. Blower shuts off shortly after burner shuts off leaving a hot heat exchanger. After 15 seconds blower comes on again blows for 10 seconds shuts off comes on in 15 seconds blows...
The fan limiting switch is acting up. It should stay running until lower temp is reached. It will cycle until the temp stays below or at the low setting. Limit switches are adjustable.
Jun 09, 2009 | Coleman Propane Forced Air Heater...
W300 WONT TURN ON WONT CHARGE!
i happen to me you need to find a friend or a family that has the same phone that you have and that your problem solve!
Dec 28, 2007 | Sony Ericsson W300 Cellular Phone
Samsung Eternity  Cell Phone Logo
170 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
