Question about Kohler Electrical Supplies
Kohler confidant 4 generator will not run.
I have a Kohler confidant 4 generator (model 4CKM21)in our RV. it ran fine 4 weeks ago. Now it kicks but will not run. Disconnected temp, and oil press sensors as well as remote starter harness. Looking at the control board, LED 2 & LED 3 come on when I press the start switch and the engine is turning over. The throttle servo opens all the way then closes immediately. If I over ride the throttle by hand it starts running for a couple seconds, but then LED 2 & LED 1 come on and it shuts down. LED 5 comes on while the engine is shutting down. Any ideas??
I got the same gen and with the same problem
mike
Posted on May 06, 2010
2 Suggested Answers
  • 5603 Answers
SOURCE: kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Posted on Aug 11, 2009
I have a Kohler Confidant 5, model 5ckm61 generator in my RV, serial # 338225, spec# 101218. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depressed ....
The control board needs to sense a voltage coming of stator windings to complete the run circuit or else it will shut down. Check the stator and rotor windings for resistance and shorts
Oct 21, 2013 | Electrical Supplies
No spark on kohler generator 4ckm21
I don't have any idea what Carl just said, but remove the little ground wire from the coil and try to start the engine. If it fires and runs ok, you have a grounding issue somewhere and need to follow the wires around to see if anything that shouldn't be touching metal, is.
Oct 10, 2013 | Kohler CH25 PA-CH730-0040 Command Gasoline...
My kohler 4ckm21 generator starts great but will run for 8 min. and shut down ?
If it runs that long, you may have a bad oil pressure switch, loose connection, or fuel pump. You didn't indicate whether the time was under laod or not
Aug 07, 2013 | Kohler Electrical Supplies
I have a Kohler Confidant 5, model 5ckm21 generator in my RV, serial # 326827, spec# 101228. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depresse
no 14vac coming from generator to control board.--cause can be regulator board on end of generator---dirty brushes or worn out brushes==b1 and b2 winding open that outputs the 14vac--my problem was blown regulator board
Dec 05, 2012 | Kohler Electrical Supplies
Kohler generator wont stay on
Check the oil pressure switch, and oil level first. Then check rotor brushes and rotor slip rings may need polishing. If the problem is still there check stator and rotor windings
Aug 25, 2012 | Kohler Electrical Supplies
Kohler Confidant 4 puts out to much voltage
Are you running the gen and plugging in the RV at the same time? I assume it is wired right and you have a transfer switch? Are you saying the voltage is fine when the RV isn't plugged in?
Apr 15, 2012 | Kohler Electrical Supplies
Kohler Confident 7 model 7CCKM22 generator
sounds like a relay should be latching one it has started
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
Kohler confidant 4 generator service manual and wiring diagram
Aug 11, 2009 | Electrical Supplies
Electrical Supplies Logo
1,837 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
