Question about Nokia e65 Cellular Phone
I could not able to answer the incoming calls.My phone is showing that the headset is on even without any connection to the external headset
My Plantronics Voyager Pro begin emitting a continual ringing when I pair to my Blackberry. I've tried deleting the headset and re-finding it and it still rings when connected. This issue first appeared...
It sounds like a defective headset. Call Plantronics directly at 1-800-544-4660 x 5538 to troubleshoot and if it's defective, they will assist in a replacement.
Good Luck from Headsets Direct!
May 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
How to talk and answer a call with nokia headset AD-44
When the headset is connected to your fone and there is an incoming call, just press the small button on the headset and you will be able to answer the call.
Jun 16, 2010 | Nokia Original Headset AD44 HS44 for 5700...
Bluetooth is paired and on but instead of answering calls, send call straight to voicemail.
Is there a visble window setting You may have to change it to be visible to your phone for more than a few minutes. Check your setting on answering or sending all incoming to the answer machine. Press the large face button to answer a call.
http://safemanuals.com/user-guide-instructions-owner-manual/PLANTRONICS/EXPLORER%20220-_E link to playtronics for user manual.
Apr 15, 2009 | Plantronics - Bluetooth Headset Plus Base...
The headset icon always appear in my nokia n70 and cannot remove and when i connect my headset ... it doesn't work . with or without headset the headset icon always appear in my screen . During incoming...
Feb 25, 2009 | Nokia N70 Cellular Phone
Nokia 2610 Problems with headset.
I think that when you connected the headset, the internal connection got jammed and even if you remove the headset it will show that the headset is connected.you should see a mobile repairer.the problem is internal
Sep 04, 2008 | Nokia 3110 Cellular Phone
Uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Jan 20, 2008 | Uniden Cordless Phone
Tapping the answer button does not answer the phone
I had the same issue until I realized that I was touching the button twice,- first answering the incoming call, then immediately hanging up!
When you first tap the button there is a slight delay and the incoming call seems to be still ringing but you've really already "answered" it. Just tap once, be patient a couple of seconds and say"Hello". Your caller will be there!
Dec 12, 2007 | Motorola Mobility H500 Wireless Headset
H350 HEADSET
you may have the earpiece volume too low, because you will only recieve a bleep when there is an incoming call, not a ringing tone, or just set it to auto answer in the phone settings.
Aug 10, 2007 | Motorola Mobility H350 Wireless Headset
Nokia e65 Cellular Phone Logo
49 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
