Question about Brookstone 538744 Remote Control
My remote worked on my tv and now it won't...I think it got decoded...how do I fix it
  • 403 Answers
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Posted on Sep 25, 2009
  • James Chavez Sep 25, 2009
    Note:
Va19l hdtv10t volume is at 100 and control panel will not come up,
Rick
Do you have other devices connected to your t?
Such as a router, a decoder or an apple tv? If you have, restart them and change the batteries in the remote. You may think that is a silly suggestion, but changing batteries in remotes has helped me more than once. Oh and do not forget to check all cables and connections as well as the power. This method does not always work the first time, in my experience it works. Patience and coffee.
kolbrun
May 26, 2014 | Vizio VA19LHDTV10T 19 in. LCD TV
No remotes work
WHAT WENT WRONG WITH THE ORRIGINSL REMOTE. NEED NORE INFO. If the remotes are not working , is the TV reciving the signal from the remote rather than the remote sending the signal .If the TV is reciving it the light should flash on TV every time it receives a message from remote. if this is not happening it sounds like the decoder in the TV needs replacing / LED might just need cleaning to open access to the sight of view. Jeff
Mar 21, 2014 | Vizio 42 in. LCD TV
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
My remote wont work on my grundig gu15wdt/gu15wdpcx, have tried changing the batteries and it still doesnt work, where can i get a new one?
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Lastly, please don't by a remote with confirming it is a remote problem. You have to be sure before thinking of a battery replacement.
Regards.
Jun 09, 2011 | Grundig GU19WDVDPCX 19 in. LCD TV
Need to connect my DSTV decoder through my sony amplifier (5.1) not sure of a the cabling or the connections, does someone perhaps ahve a wiring diagram to connect TV, dstv decoder and sony 5.1 amplifier?...
well this is easier than you think, get yourself a set of RCA's (the red and white and yellow cables that DVD players come with) look behind your decoder and place them colour to colour, then behind your Amp you will read (TV IN) do the same, then with just one yellow RCA plug it into (monitor) that one will then go to the (AV input) behind your TV.. And presto!!! now set your amp input on the remote to TV and your off!! good luck
Jun 29, 2009 | Fujitsu Siemens PlasmaVision P42VHA40...
Cyberhome dvr1600 remot
try replacing the decoder.. i have same problem but i solved it by replacing the decoder... the new one..
Mar 13, 2008 | Cyberhome CH-DVD 300 DVD Player
Brookstone 538744 Remote Control Logo
65 people viewed this question
Top Brookstone Televison & Video Experts
L Pfaff
L Pfaff
Tom Chichester
Are you a Brookstone Televison and Video Expert? Answer questions, earn points and help others
