Question about PfaFF Sewing Machines
Pfaff 1471 will not run.
I have a Pfaff Creative 1471. It was taken in for service, and the foot-feed was tested. The motor is the problem. I couldn't begin to count the hours of use on this machine. It is no surprise that the motor has given out. However, for a machine that had original purchase price of around $2000; I would have thought it would be easier to find parts. I am likely going to remove the motor, and take it to a shop that rebuilds electric motors. The few motors I have seen online were in excess of $200, and were Pfaff motors for models other than the 1471. A standard motor rebuild should cost somewhere around $50, for new brushes and a re-wind.
If you want to play with it, you may be able to make it work for a while by slightly lengthening the springs that hold the brushes in. You will likely have to remove the motor to do this. There are opposing caps on the motor that are threaded and have screw slots. You will need to remove the caps, and remove the brushes. The springs are set so that the steel spring will not run into the copper when it runs out of the soft carbon brush material. You should not lengthen the spring to any more than the actual depth of the hole it fits into. If you do, there is a good chance that the spring will chew up the stator, or the copper face that the brushes ride on. If this fully resolves the issue, then you should find new carbon brushes (2) for the machine and replace them.
SOURCE: Pfaff 2170 Query
my pfaff 2170 machines shows "Cannot make Directory" pls help me in this
Posted on Jun 27, 2008
SOURCE: Lengthening stitches.
You can adjust the length of the Zigzag (Satin)
Stitch using the buttonhole fine-adjusting screw. You will find it right above your stitch selection dial.
> For a longer stitch length, turn the
buttonhole fine-adjusting screw with a large
screwdriver in the + direction.
> For a shorter stitch length, turn the
screwdriver in the - direction.
Hope this helps
Posted on May 18, 2009
  • 980 Answers
SOURCE: what year was serial number 82848782 produced?
The 1471 first came out about the early 70's
Posted on Oct 27, 2009
  • 8 Answers
SOURCE: can a circuit board be repaird for a pfaff 1471?
I just got a quote for a replacement board for a 1475. It's approx $480 though. Talk to your Pfaff dealer. Mine did a free estimate.
Posted on Dec 29, 2009
  • 980 Answers
SOURCE: I am working on a
Remember that the needle on the 221 goes in with the flat side to the right and you thread the needle right to left, try that first.
Posted on Feb 12, 2010
Pfaff 1471 threading instructions
Hello Patricia P. Thomas
Download a free Pfaff 1471 Manual here
The threading instructions are quite simple to follow.
Please let me know how this works out for you.
Happy Stitching
Feb 27, 2017 | PfaFF Sewing Machines
Can't find fuse on Pfaff creative 1471
Where is the fuse on a 1471 Pfaff sewing machine ?
Aug 20, 2013 | Brother CS-80
I have a Pfaff Creative 1471 and the pressure foot is very slow to come down and then is not keeping the proper pressure on the material. How do I open the machine to see if I just need to clean and oil?
I have had my machine for many years and this is about the only problem I have had with it. I had taken it to 2 different repairs shops about 2 years ago and the repair worked only temporarily. The only reason I had not tried this solution before is that I didn't know how to get the side cover off to reach the mechanism. I just recently learned how and the oil worked like a charm after a little cleaning with a Q-tip. At least now if the problem reoccurs, the fix will be easy and free.
May 21, 2010 | Sewing Machines
I have a pfaff creative 1471 and it seems like the pressure foot, when raised, then lowered, doesn't have the proper down pressure. It sticks in the up position, then when I pull it down, it sorta snaps...
Can't believe no one answered you. I would highly suggest you take it in. From my searching around learning about the Pfaff 1471 I was just given. I found it is a very good machine and well worth spending well up to 500 to keep it in good shape. I just had to cut back on the extra I pay on my car payment just to pay the 150.00 tune up on her (ouch). But she runs like a dream now. The machine is so good I didn't even notice she needed it. What you seem to be saying wrong seem to be the most common thing I have read goes wrong with the 1471. I get there is a spring that gets gummed up. It should be replaced/cleaned and regressed by a pro. If its as common as it sounds shouldn't cost more than what I paid.
Mar 29, 2010 | PfaFF Sewing Machines
Presser foot 7 lever on Pfaff 1471
You may not be using the correct presser foot for your machine.
Sewing Machine Feet
You may be using a low shank when your machine needs a high shank.
May 12, 2017 | Kenmore 15218 Mechanical Sewing Machine
Sewing Machines Logo
189 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
