Question about Samsung Digimax S500 Digital Camera
It got stuck with the lens out and it doesn't get back in. No buttons respond.
I was taking a picture and as soon as I hit the shooter the screen turned itself off and there was no sound of a picture being taken, nothing on the screen, the lens out and when I try to turn it off the power light gets lit but no response. I took out the batteries and put them in again and nothing. I live in Guatemala and in both the International warranty and the manual there's no guatemalan address for technical service nor does it say where to send it. Please help. The camera has always been treated carefully so I am sure there was no negligence involved.
  • Keihan Dec 22, 2007
    I just got that same problem today. I treat it with a ton of care, but it still got messed up. I'm working on a project, too :I
    I think samsung cameras just suck.
  • Samsung Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
WB610 Camera buttons & lens aren't working as they should?
As soon as the camera is switched on, the lens barrel will come out. Everything should be ready to shoot pictures. If it is not responding to the buttons, you could try to remove the battery for a few moments. It will cause the camera, to start from scratch. Call it a cold boot. But then after switching on, it should respond normal, like you used to work with it. If it stays frozen, visit your dealer or contact a Samsung certified repair centre.
Mar 10, 2015 | Samsung WB610 Digital Camera Black
Hi. my problem with my camera is that my niece play with it and she pushed the lens mechanism while the camera is on. now, the lens was stuck and doesn't comes out anymore. when i'm turning on
Force it out like it was forced in. Try to rotate the lens. Remember it has to be off. As soon as the lens is half way out, turn the camara on and the lens will go to its position. If not, while the lens is out turn it left or right until it's back to its position.
Good luck.
Aug 24, 2012 | Sony Cyber-shot DSC-W55 Digital Camera
When I click the button to take a picture the screen goes blank and doesn't come back on. Power light is still on.
Your shutter is stuck open. Remove the lens. Set to fireworks mode. May need to be in a dark room. When you press the shutter button tap the camera with an object that won't damage it. I used a rubber coated knife handle. Pull the battery and repeat. Tapping all around the camera. Hopefully it will break free. Then do some continuous shooting to loosen it up.
Nov 27, 2011 | Olympus PEN EPL1 Digital Camera
Our camera seems to be okay but when i'm attempting to get picture, i can't see any image in LCD, is it the lens?
First try pressing the DISP or DISPLAY button on the back of your camera. If that doesn't help, try taking a picture with the screen black. Is the picture also black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 13, 2011 | Sony Cyber-shot DSC-S750 Digital Camera
Hi my Canon Powershot SD 750 LCD screen stays black when taking pictures, you can't view them either. The only thing that shows up on the screen is the menu functions, you can look through everything...
First try pressing the DISP or DISPLAY button on the back of your camera. If that doesn't help, astuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 05, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
Olympus sp565 shutter button is malfunctioning
I will second that. I can't seem to find a solution for the exact same problem. I tried to take a picture but does not respond, If I take the batteries out and put them back in as soon as I turn it on it takes a picture, then doesn't respond again. AHHHHHHH. Ive only had this camera for about 18 months and I'm so disappointed. I had a fujifilm 5600 Which I passed onto my sister we both have never had a problem, it's 5 years old now and still going strong, Now my camera is wiggin out and I need it to work ASAP CAN ANYONE HELP US
Jun 13, 2010 | Olympus SP-565 UZ Digital Camera
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
Feb 07, 2010 | Canon PowerShot A620 Digital Camera
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Camera won't turn on/lens extended
General system failure- Contact Samsung for repair cost.
Aug 30, 2007 | Samsung Digimax S500 Digital Camera
Lens
Switch off and on again? Take battery out and replace. Thats the only 2 ways of 'restarting a camera that I know of. Does your model have a 'reset' function? You will have to check the manual for that. Or ask Canon support.
Aug 22, 2007 | Canon PowerShot A460 Digital Camera
Samsung Digimax S500 Digital Camera Logo
61 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
