Question about HP DeskJet 932c InkJet Printer
Deskjet 932C. Won't feed paper.
It will feed and print the test page fine. But form feed button will not feed a page and eject it. Printing a document from the computer will fail with a print error (not an out of paper error). It doesn't make any noise or attempt to feed the paper. Since it prints the test page fine, the print mechanism seems to work fine. I have examined the printer for jammed paper and such to no avail. Please advise.
    President:
  • HP Master
  • 2,017 Answers
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Posted on Sep 24, 2009
I changed the black cartridge in my hp 932c and now there is a faint double image of everything in black. I switched cartridges and still have the problem.
The Deskjet 932 has a sensor that allow the printer to perform an automatic calibration whenever a cartridge is changed. It should not be necessary to ever manually force a calibration, but if you want to you can do it from the front panel as follows:
1. Turn on the printer.
2. Press and hold in the power button.
3. While holding the power button in press and release the form feed button three times quickly.
4. Release the power button.
This will print a calibration page which will be scanned automatically as part of the process. The calibration may fail if the 78 cartridge is not properly printing yellow or the 45 is not printing properly. It may also fail if the sensor is fogged with aerosol. This can be resolved by cleaning the sensor with a damp q-tip. The sensor is located in a small black plastic box located in the lower right rear of the carriage.
Mar 01, 2010 | HP DeskJet 932c InkJet Printer
HP Deskjet F4200, prints blank page
I went into print settings after failing the diagnostics.
Printing normally would just feed the paper through with no ink.
I set the settings to specifically "Fast Draft" and adjusted
minor things like paper to A4 and color to grayscale for the
print job at hand.
Bingo!
Sep 09, 2009 | Office Equipment & Supplies
Both paper feed and power lights flash after printing several pag
lean head-eject ink ruler & clean point of contact betwin cartridges and head-ink unit.
Aug 07, 2009 | HP DeskJet 970cxi InkJet Printer
Nor printing
Test page is from 4 second 2 buttons press? Or from Windows print window? If you are LPT1 try a USB cable? Perhaps a port conflict or motherboard flaw.
Aug 03, 2008 | HP DeskJet 932c InkJet Printer
HP Deskjet 6540 Alignment
Yeah, the only thing that can cause this is paper feed problems.
There must be either something loose in the paper feed mech (look for wobbling "tires") or there is still some paper or other foreign debris in the paper feed path.
Jul 03, 2008 | HP DeskJet 6540 InkJet Printer
Paper feed
hi, do you notice any intake activity when u hit print in word etc???check word print properties.. let me know
Dec 09, 2007 | HP DeskJet 820Cse Printer
Not printing color
Loks like there is a "well" under the "docked" position of the heads (at the right end of the unit, facing it - under the control buttons.) In my unit, ink had built up in this well to the point that some of the mechanical bits were scraping the top of the built-up ink pile. After I carefully removed about two TootsieRoll's-worth of old dried ink with a long scewdriver (using a flashlight to illuminate the area), the color printing seemed to be doing better. Can't tell yet if this has completely resolved the problem, as I have not yet printed enough pages to prove the point...
Nov 05, 2007 | HP DeskJet 932c InkJet Printer
Deskjet 895Cse is "sucking" paper in and stalling
Sounds like the printer is getting a bad command from the driver. Try upgrading your driver. Also it may be a bad document. Copy and Paster your text into a new document to see if it clears the corruption.
Sep 28, 2007 | HP DeskJet 895cse InkJet Printer
HP DeskJet 932c InkJet Printer Logo
246 people viewed this question
Seeker5211
Seeker5211
