Question about Kenmore 24032\24036 Top Load Washer
Washer stopped working
While spinning the agitator stopped working properly,motor kept running,dont know how long,but there are belt shavings on the side,now it only buzzes when turned on,is there a reset button for motor,and as for the agitator,will something be stripped,or could it be as simple as a new belt,long shot ha.
washer was in middle of cycle, blew circut breaker, reset the breaker now washer buzzes when I turned it back on.
  • Anonymous Dec 31, 2007
    having the sam eproblem with a different model not sure what happened. Now only buzzes when I turn it on and full of water.
    Scholar:
  • 196 Answers
To help you with this problem I need you to do something. Place the machine in spin cycle and see if it will pump the water out. Also, lift the lid and look at the back. There should be a model/serial number plate. This information would help.
I do not believe the motor is at fault. I suspect a bad motor coupler. If the machine willpump the water out then I am Sure.
Posted on Jan 02, 2008
Machine filled with water then stopped running
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Apr 07, 2015 | Washing Machines
Our whirlpool wtw5100vqo agitator doesn't work I already replaced the agitator dogs
Apr 03, 2015 | Whirlpool Washing Machines
My Amana Tandem 7300 front load washer gives an f5 e3 code. It would start spin once then stop and make a click/buzz noise then beep three times then shut off. The door latch mechanism was replaced, ...
Feb 28, 2015 | Amana Washing Machines
My washer want do nothing it will run the water but thats it I use it all this morning I have a maytag centennial commercial technology
Feb 07, 2015 | Maytag Washing Machines
My washer door is locked with the motor running but no water coming in and the tumbler not tumbling. I can only turn it off if I unplug it.
Jul 25, 2014 | Whirlpool Duet White Front Load Washer -...
The washer doesn't spin
Possible that the belt is slipping due to overload, check the capacitor to the motor , check the belt to the motor, check if the spindle is jammed , if so reset the spindle.
Jan 18, 2013 | GE WBSE3120B Top Load Washer
Drum doesn't spin or agitate. Only drains. Timer works.
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It doesn't agitate If your washer doesn't agitate, check these: Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys
Jan 02, 2010 | General Electric WJRR4170GWW Top Load...
Clothes washer will not agitate or spin
reply to me with brand and model number may can help but dont rate me till we are done
Jan 10, 2008 | Washing Machines
Washer Problems
I have the same problem with my GE washer (GJXRP080B2WW). We started the washer before going out and when we came back home. The cycle finished and the cloths were clean but all wet! I then tried again and it did fill water and drain but didn't agitate or spin. I checked the lid switcher, the timer and the agitator which are fine. However, the motor belt doesn't move and it seems the motor doesn't work when power was on. There are a lot of wires connected to the motor and I don't know which one to check to be sure power goes to the motor. Could you please help me? Thanks.
BTW, I didn't find any Reset button or the start capacity...
Dec 18, 2007 | GE WJRR4170E Top Load Washer
Agitator stopped working
depending the age of the unit the lid switch can be bad if not that old take front panel off and the newer machines have a motor wit a control board on them with a light on it to give you error codes if it flashes one flash every few seconds the motor is fine but if the light flashes twice over and over again replace motor there is a tech sheet behind timer panel to tell ya the codes.as far as shavings the belt would be something to look in to
Dec 08, 2007 | Hotpoint VVSR1070D Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
63 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
