Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Where is the power supply located in a samsung HLN5065W?
  • Samsung Master
  • 5,138 Answers
Follow your AC cord that plug into wall outlet it goes to Power supply board located on far left side up front . Whats wrong with your TV? Maybe I can help you.
Posted on Sep 24, 2009
Samsung HLN5065W Color/Power problems
Good day!!!!
Kindly check the power supply board..Look at the capacitors within check the visual condition if it is look like bulged,leak or burnt..
If that so,try to replace it with the same type ratings and value..you can order that parts on local or online..
This is the sample images:
Dec 19, 2011 | Samsung HLN5065W 50" Rear Projection...
NONE OF THE FANS ON MY SAMSUNG HLN5065W TV WORKS.
Each fan has 3 pin connectors on digital board, check its voltage supply approx +10V on its connector, if volts are not present, follow the line that goes to power supply board and find out any fuse or some thing might blown and causing no volts to fans to run.
Thanks.
Aug 02, 2010 | Televison & Video
Tv turn off afterbeeing on for afew minutes
COULD BE THE LAMP IS BURNED OUT, COOLING FAN NOT WORKING, A BAD BALLAST OR BAD POWER SUPPLY. CALL 1-800-SAMSUNG FOR NEAREST SERVICE CENTER.
Nov 24, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W TV...picture freezes and will not
I solved this issue by junking it and buying a new one.
Oct 08, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W color wheel installation
Check the wire connections one may be loose or not properly seated
May 11, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W shuts down in a minute
2 tings, ,lamp fan motor stops or temp. sensor located on optical block activated
Mar 01, 2009 | Samsung HLN5065W 50" Rear Projection...
A Samsung Tv model #HLN5065W
Model # HLN5065W Digital Main Assembly Board should be part # BP94-00385A. Here's a link to a major Samsung distributor:
Samsung HLN5065W Replacement Part Digital Main Assembly Board
***There's also a manufaturer's notice: If you replace the digital main board (BP94-00385A) you must replace the main analog board (BP94-00434A) per mfg bulletin# ASC20040728004.***
Samsung HLN5065W Replacement Part Main Analog Board
Dec 30, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
Jerry Greenberg
Jerry Greenberg
