Question about Seiko SNA311 Wrist Watch
Hour hand stops at 10 oclock - Seiko SNA311 Wrist Watch
    Sniper:
  • 59 Answers
Could be
1, Need New battery
2, Hands touching & blocking each other
3, Watch required cleaning / overhaul for movement
any expert watch maker will do that or if you in chicago bring it to us
we do repair and provide free estimate
hope this help
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Posted on Sep 24, 2009
The hour hand on my grandfather clock is floppy after pushing it back to alter time and just falls to 6 oclock
Push it firmly towards the clock. Usually they are just a friction fit and if you push it, it will jam back onto the shaft.
May 18, 2016 | Watches
Clock Manuals
leave it running when it gets to 12 oclock it wiil reset itself
May 02, 2013 | Watches
Zero in second hand
Easier than you think.Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Aug 29, 2010 | Invicta Subaqua Noma Iii S
Kaiser clock model kc-2. The cuckoo doesn't go off on the hour and I want to know how to set it so the cuckoo will go off on the hour.
remove the batheries and then advance the mintue hand slowly until you hear a clicking noice then remove both the hour and minute hand and place both at 12 oclock high postion advance the minute hand again to confirm you hear the click noise when the minute hand is at 12 and the hour hand is at 1. then replace batteries and the clock should cuckoo properly on each hour,,,,,best regards
kaiser clock
Aug 04, 2010 | Watches
The 24 hour hand sticks at the 12 oclock posiion on my omega seamaster gmt every 24 hours the hour hand will not pass this position.
It sounds as though the 24hr hand is being obstructed, and that is also stopping the 12hr hand. Try to examine the face carefully for foreign objects (or bent hands). Unless you're very skilled with watches, I would suggest that you take it for repair. If the hands are sticking, gently pull out the crown ("winder") to stop the watch and prevent further damage.
Jul 19, 2010 | Omega Seamaster 2561.80 Wrist Watch
I have a forestville wall clock with the pull down weights. when it chimes it is behind in time. example nine oclock chimes seven oclock, it is a made in germany clock but what year i do not know. there...
Stop the pendulum of the clock exactly at any even hour. Lets say at 6.00. While clock is steady and not working, pull off the minute and hour hands off the pinion, but do not brake them. You have to pull without any twisting action. This will leave pinions exactly in place they were when you stopped the clock. When it is done - push the hour hand back onto the pinion and make sure it is pointing at 4 (not 6, as it was when you stopped the clock). When hour hand is back in place and pointing at 4, push back minute hand as it was when you pulled it off - pointing at 12. Make sure hands will not catch when passing each other (you can bend them slightly if needed). Now swing pendulum to start the clock and adjust time (clockwise only). Never adjust time when clock is chiming. Rate me, plz.
Feb 02, 2010 | Watches
Can't set Seiko Yacht Timer Sports 150
Turn knob to set on "Match" Pull out crown knob. Press both buttons for 3 seconds. When you release both buttons it will beep and both hands start moving. Press either button to stop movement. Then press the top button to set the minute hand to 12 oclock. Press the bottom button to set hours to 12. Press in crown and turn to "Time" Pull out crown and set time the same way.
Mar 01, 2009 | Seiko Le Grand Sport SDWF73 Wrist Watch
Crane and Viceroy ladies RC watch
Hi, Klik and Crane & Viceroy are excellent and robust watches, but due to the radio control batteries need to be changed more often than ordinary watches. Instructions for resetting the time on a Klik or Crane & Viceroy watch. With the watch face upwards and the buttons on the right assume the buttons to be; top button - "A", middle button "B" For setting the watch to GMT all hands need to point to 12 oclock exactly. To achieve this press Button A until the hands start spinning. Stop the spinning when the time reaches a couple of minutes before 12 oclock by repressing A. Inch the time forward by repressing Button A until all hands are at 12 oclock.(EXACTLY). Press Button B within 10 seconds and the time will advance 1 hour and stop. The radio signal will be picked up automatically and time will set itself in a few minutes. Notes: If you have radio dead spots avoid these when resetting the watch and do it away from magnetic or large metal objects. i.e. trays etc. If you are refitting a new battery and have a battery that isn't quite dead, do the advancement of time with the old battery and fit the new one near to 12 oclock to get the best life out of the new battery. If for any reason you want the watch to be in radio mode but read a time other than GMT ( no adjustment is needed for BST ), then instead of stopping the watch at 12 oclock stop it at the time in relation to 12 oclock. i.e. if you wanted the watch to read 30 minutes fast then stop the watch at 12.30. if you want any other info my email is; Charles@adept.fsbusiness.co.uk
Jul 15, 2008 | Watches
Klik r c watch.
problem solved.
regards.
Matt.
Apr 17, 2008 | Watches
Seiko SNA311 Wrist Watch Logo
Top Seiko Watches Experts
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
