Make sure you back up your database before uninstalling. If you don't plan on a reinstall, that's not a problem.
Download the file...Save it to your Desktop, don't run it from the download. After the download is complete, run (double-click) the file on the desktop.
NOTE: This will uninstall ALL Norton products. If you have others you will need to reinstall them. Make sure you have a legitimate CD Key and are registered at Symantec.
When I am in the send fax screen, I have three prblems:
1. My default cover page has text with...
(More)
1. My default cover page has text with inserts in it. When I view the cover page on this screen, the text seems to be in two layers. One layer has the variable inserts (@C, et al). The other layer has the text as it will display when I open the annotation screen. How is this corrected?
2. About every 4 times I send a fax, When I add attachments, I get a general default error and I have to close out of Winfax. I have to go to task manager and manually exit the three services that are running. Frequently, the WinFax controller is in on the task bar (lower right side) in duplicate. How is this corrected?
3. I want to insert a logo on my cover page. When I do this, I can only see the graphics object that is cross hatched, but the logo is not there. Is thier a problem with doing this? Is their a file size or file density limit for these types of graphics?
Just installed WinFax 10.02. I can't get WinFax to initialize. At the CSID screen, it immediately...
(More)
Just installed WinFax 10.02. I can't get WinFax to initialize. At the CSID screen, it immediately drops out.
When I attempt to open Winfax pro, the message manager screen never fully opens and the hour glass...
(More)
When I attempt to open Winfax pro, the message manager screen never fully opens and the hour glass remains constant. The same is true with ACT 4.0
can t use winfax anymore. have always this message another user on this computer is using winfax....
(More)
can t use winfax anymore. have always this message another user on this computer is using winfax. please try again later turned off the fastswitching user option recommended by symantec but nothing solved
