Question about Nokia 6590
I HAVE SET MY GPRS SETTINGS TO WAP.CINGULAR AND STILL CAN'T CONNECT TO THE WEB ON MY PHONE. ARE THERE ANY OTHER SETTINGS I NEED TO CHANGE ON THIS PHONE TO ENABLE IT TO CONNECT?
Cingular WAP settings
Hi..i am providing you with the WAP and other settings,but still if you need any help,then please contact Cingular at 866.CINGULAR(866-246-4852)
For CSD (Wireless Internet)
Function Setting
Settings Name: Cingular Wireless Internet
Home Page: http://device:home or http://device.home
Session Mode: Permanent
Connection Security: On
Dial-up Number: 14152441012
Gateway IP Address: 66.209.11.61
Authentication Type: Secure
Dial Type: ISDN (on network)
Analogue (off network)
Login Type: Automatic
User Name: WAP@CINGULAR.COM
(All upper case)
Password: CINGULAR1
(All upper case)
For GPRS (Wireless Internet Express)
Function Setting
Settings Name: Cingular Wireless Internet Express
APN: wap.cingular (lower case)
PDP_Type: IP
User Name: WAP@CINGULARGPRS.COM
(All upper case)
Password: CINGULAR1
(All upper case)
Now to set up MMS (Multimedia Services)
Homepage: http://mmsc.cingular.com
Gateway IP 1: 66.209.11.61
Port 1: 9201
Domain 1: (blank)
Service type 1: WAP
Gateway IP 2: (leave alone)
Port 2: 9201
Domain 2: (blank)
Service type 2: WAP
DNS 1: (leave alone)
DNS 2: (leave alone)
Timeout: 10 minutes
CSD No.1 14152441012
Username 1: WAP@CINGULAR.COM
password: CINGULAR1
Speed(bps): 9600
Line type 1: ISDN
CSD No.2: (blank)
User Name 2: (blank)
Password 2: (blank)
Speed(bps)2: 9600
Line type 2: ISDN
GPRS APN: wap@cingular
Username: WAP@CINGULARGPRS.COM
Password: CINGULAR1
Good luck :-)
Apr 22, 2010 | Computers & Internet
Problems with an unlocked Samsung A717
double check your settings, try using gprs. You can get those settings from your service provider.
Jul 13, 2008 | Cell Phones
No internet connection it is a unlock phone from t mobile to att
Hai, Go into Web Sessions and change the Internet and MMS settings to those appropriate for AT&T. If the T-Mobile settings are locked, create new settings and make them the the default. Each carrier has its own setting but those settings are the same for any phone on that carrier's network.
Browser Settings (in web sessions): ---------------------------------------------------------------------------------------------------- Name: Cingular Wireless Internet
Homepage: http://device:home or http://device.home Service Type 1: WAP Gateway IP 1: 66.209.11.61 Port 1: 9201 Domain 1:  Service Type 2: WAP Gateway IP 2: 000.000.000.000 Port 2: 9201 Domain 2:  DNS 1: 000.000.000.000 DNS 2: 000.000.000.000 Timeout: 15 minutes CDS No. 1:  User Name 1:  Password 1:  Speed (Bps) 1: 9600 Line Type 1: Modem CDS No. 2:  User Name 2:  Password 2:  Speed (Bps) 2: 9600 Line Type 2:  GPRS APN: wap.cingular User Name: WAP@CINGULARGPRS.COM Password: CINGULAR1 ------------------------------------------------------------------------------------- MMS Settings (in web sessions):
Homepage: http://mmsc.cingular.com Service Type: WAP Gateway IP 1: 66.209.11.61 Port 1: 9201 Domain 1:  Service Type 2: WAP Gateway IP 2: 000.000.000.000 Port 2: 9201 Domain 2:  DNS 1: 000.000.000.000 DNS 2: 000.000.000.000 Timeout: 15 minutes CDS No. 1:  User Name 1:  Password 1:  Speed (Bps) 1: 9600 Line Type 1: Modem CDS No. 2:  User Name 2:  Password 2:  Speed (Bps) 2: 9600 Line Type 2:  GPRS APN: wap.cingular User Name: WAP@CINGULARGPRS.COM Password: CINGULAR1 ------------------------------------------------------------------------------------------------ MMS Settings (in Message Center>>>Message Setup>>>MMS Message Setup): Hide fields: Cc.Bcc.Priority Autosignature: Download: Automatic Filter: Expire After: 5 days Reply Type: MMS Size Limit: None Server Info: Cingular MMS>>>Select Server Info>>>Current Server>>>New: Service Name: Cingular MMS
Server Name: http://mmsc.cingular.com Web Session Name: Cingular MMS.
Some settings may not have to be entered for all phones because they are set at the default for those models. You can leave the User Name and Password fields blank.
Aug 04, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Can't receive picture message
Wap
Homepage: http://device.home
Service type: WAP
Port 1: 9201
Domain 1:
Service type 2: WAP
Gateway IP 2:
Port 2:0
Domain 2:
DNS 1:
DNS 2:
Timeout: 10min
CSD No 1: cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif+14152441012cb_transparent_r.gif
User name: 1: WAP@CINGULAR.COM
Passwrd 1: CINGULAR1
Speed: 1: 9600
Line Type: ISDN
CSD No 2:
User name:
Passwrd 2:
Speed: 9600
Line Type 2: ISDN
Passwrd: CINGULAR1
MMS
Service type: WAP
Port 1: 9201
Domain 1:
Service type 2: WAP
Gateway IP 2:
Port 2:0
Domain 2:
DNS 1:
DNS 2:
Timeout: 10min
CSD No 1:
User name: 1:
Passwrd 1:
Speed: 1: 9600
change these settings in your phone under gprs and mms
May 24, 2009 | Cell Phones
What is the correct data or GPRS info for my cect i9 phone?
Hi! Your GPRS or data packet service is currently not activated and thats the reason you can't access internet. So contact at&t and get your gprs service activated first and if it is activated then under your phone connection settings input the following settings-
GPRS Settings:
PDP_Type: IP
Port: 9201
(All upper case)
Password: CINGULAR1
(All upper case)
MMS Settings:
Service Name: MMS
Server Name (mmsc): http://mmsc.cingular.com
Web Session Name: MMS
Leave user name & password field blank
Also if above settings don't work then try-
148.233.239.24
Port 3128
or
APN: proxy
UserId: leave blank
Password: Leave blank
Browser settings:
IP: 10.250.250.250
Port 9203
home page: http://home
with rest things same
Dec 27, 2008 | Cell Phones
Need help with my lg shine ke970
Set the homepage to: http://device.home
Set the Bearer: GPRS
GPRS settings:
APN: wap.cingular
User ID: WAP@CINGULARGPRS.COM
Password: CINGULAR1
1. Scroll to and select Proxy Settings and press OK.
* IP Address: 66.209.11.32
* Port Number: 80
2. Press the End call key to return to the standby screen
I found this on the web, its a little different then how I did mine, so here it is in case mine doesn't work for you:
here you go...it works !!!
Phone Setting>Connectivity>Access Point: (Data Setting)
Title: Att
Bearer: GPRS
Auth: PAP
User: WAP@CINGULARGPRS.COM (all caps)
Password: CINGULAR1 (ALL UPPERCASE)
APN: wap.cingular
Browser>Settings>Profiles: (Internet Setting)
Service Name: Media Net
Homepage: http://www.google.com
Connection mode: TCP without proxy
IP: (blank)
proxy: (blank)
Security: (blank)
Access Point: ATT
Messaging>Settings>MMS>MMS center: (MMS setting)
Title: ATT MMS
MMSC URL: http://mmsc.cingular.com/
Connection Mode: TCP with Proxy
Access point: ATT
Oct 16, 2008 | LG Shine KE970 Cellular Phone
Unable to send txt msg with pictures on SGH-U600 unlocked!
Goto this website:
http://uk.samsungmobile.com/supports/supportMain.do?&menuIdTop=00000000000003
On the left hand side under configure phone it says WAP and MMS settings
To send picture messages it is the MMS settings you need
Click on the MMS and follow the instructions
Apr 28, 2008 | Samsung SGH-U600
Unlocked european phone MMS
wrong! ive got an unlocked european phone and i got these settings that cingular WOULD NOT give me off the net
-= MMS Web Session =-
Menu -> Web Access -> Web Sessions -> Menu -> New
Service type 1: WAP
Gateway IP 1: 066.209.011.061
Port 1: 9201
Domain 1: (blank)
Service Type 2: WAP
Gateway Type 2: 000.000.000.000
Port 2: 0
Domain 2: (blank)
Timeout: 10 minutes
CSD No. 1: (blank)
User Name: (blank)
password 1: (blank)
Speed (Bps) 1: 9600
Line Type 1: ISDN
CSD No. 2: (blank)
Password 2: (blank)
Speed (Bps) 2: 9600
Line Type 2: ISDN
Password: CINGULAR1
-= Message Setup =-
Main Menu -> messages -> Menu -> Message Setup
MMS Message Setup (This is very critical)
Inbox View: Sender
Srvce Center No: +13123149810
Auto Cleanup: 5 days
Email Gateway: 36245
SMS Alert: On
Use GPRS: Yes
-= MMS Message Setup =-
Main Menu -> Messages -> Menu -> Message Setup ->
MMS Message Setup -> Server Info -> Menu -> New ->
Service Name: CINGULAR MMS
Web Session Name: (Choose the Web Session you created for MMS)
set to default
Mar 10, 2008 | Motorola Mobility RAZR V3
Need to use the motorolla phone to send and recieve pictures
setting up an internet conection and multimedia connection on unlocked gsmphone
Model No: Motorolla Krzr Z6 a German Market Model
1st of all make sure u have the internet connection:
creating an internet connection
menu>connection>Data connection>add a connection>
Profile Name: Atnt
Proxy 1: 66.209.11.32
port1: 80
domain 1:
gprs apn: WAP.CINGULAR
user name: WAP@cingular.com
password: cingular1
GPRS Timeout:15 min
click on additonal settings
Proxy 2:
Port 2: 9201
csd number: 14152441012
unername: WAP@CINGULARGPRS.COM
password: cingular1
speed: 9600
line type: ISDN
CSD Time out: 15 min
main menu>messages>options>settings>multimedia Messages>Service Profile
there creaate a profile
Profile name: Cingular
Service Center: http://mmsc.cingular.com
internet connection: : atnt
Then go the the browser setup
browser setup:
Menu>office tools>web access>browser setup>broser profile>add a new profile
profile name: cingular GPRS
home page: http://device.home
data connection: Atnt
cookie poxy Policy: let gateway decide
restart the phone
goldenguras@gmail.com
Feb 18, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Cant pxt or recieve tone downloads (parallel import phone)
Please verify that your settings are as follows, and then you should be all set!
From the standby screen, press the Menu Key.
Scroll to "Settings," press Select.
Scroll to "WebAccess," press Select.
Scroll to "Web Sessions," press Select.
Scroll to "Cingular MMS" press Menu.
(if not there select "new")
Scroll to "Edit," press Select.
Validate the following parameters:
Service Type 1: HTTP
Gateway IP: 66.209.11.32
Port 1: 9201
Domain 1: leave blank
Service Type 2: WAP
Gateway IP 2: 0.0.0.0
Port 2: 0
Domain 2: leave blank
DNS 1: 0.0.0.0
DNS 2: 0.0.0.0
Time out: 5 minutes
CSD no 1: leave blank
Username: 1: leave blank
Password 1: leave blank
Speed (Bps) 9600
Line Type 1: ISDN
CSD no 2: leave blank
User Name 2: leave blank
Password 2 leave blank
Speed (Bps) 2: 9600
Line Type 2: ISDN
Password: CINGULAR1
Press Done.
Press Exit.
Press Back
Press Back.
Scroll to "Messaging," press Select.
Press the Menu key.
Scroll to "Inbox Setup," press Select.
Scroll to "MMS Message Setup," press Change.
Scroll to "Server Info," press Change.
Scroll to "MMS", press Menu key.
Scroll to and select "Edit".
Validate the following settings:
Service Name: MMS
Dec 14, 2007 | Motorola Mobility RAZR V3
Nokia 6590 Logo
29 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
