Question about Philips 32PFL7332D 32 in. LCD HDTV
I unchecked my preferred channels in my menu on my 32 inch philips tv. now they are erased can i get them back?
  • Philips Master
  • 8,457 Answers
Yes,Just rescan them,uget them back.
Posted on Sep 24, 2009
Phillips TV with no on screen menu, only Caption, Text and Sleep. bought TV's from factory auction. PA5032-C102. or 32R505-00BB.
The OSD (on screen menu) is locked. Those two serials (not models) are for two completely different tv's: the first is for an very old standard 32 inch CRT and the second for an old plasma.
To unlock it in the first tv you need to just press the menu button for 10 seconds. For the second tv you must start the tv and immediately press both the menu and channel up buttons for 5 seconds.
Dec 15, 2010 | Philips Televison & Video
How do I do a channel scan?
Press Menu on the TV (second button from the left) or the remote. Use the Vol + / Vol - buttons to highlight Tuner, only available when the input is the TV (press TV/AV to get to the correct source) mode. Press Ch+/Ch- to highlight AutoProgram and then Vol+ to start the search for channels. The TV will show Tuning Finished when done and then go to the lowest channel found. If you want to add or remove stations, tune to the desired channel, then press Menu, and highlight Tuner, Ch+/Ch- to highlight Add/Erase, then Vol+/Vol- to set Add or Erase. Press TV/AV/Exit to get out of the menu.
I hope this helps.
Jul 28, 2010 | Philips Magnavox 27MS343S 27" TV
Sharp 32 inch lcd tv won't reconginze channels when connected to antenna. Why? The screen now looks like a defragmenting on a computer screen.
You probably need to do a channel scan to find TV channels and progrma them to the TV memory. Using your remote control select Menu mutton and follow instructions for "auto channel scan"
Jan 17, 2010 | Sharp LC-32SB24U 32 in. LCD TV
How to scan for new digital channels small Philips flat screen
From the menu you should see set up the cannel scan should be there.. If all else fails unplug the TV for a few minutes then plug it back in. It should ask if you want to set up the tv, Say yes and follow the steps.
Jun 16, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Lost channels on TV
do an anolog and digital channel scan see if that helps also unplug from wall and plug back in to reset see if that helps
Mar 25, 2009 | RCA F32650 32" TV
Channel search for my Phillips PL9125
You should contact to get original remote for that TV.
Nov 05, 2008 | Philips Televison & Video
Philips 32pt television screen format off center, to the left
For me it was the cable box settings...
I'm not a tech person, so take this for what its worth. I had the same problem with my Vizio and my Time Warner Cable HD/DVR box using the HDMI cord connection. HD channels were always fine, and non HD channels were fine until I went to an HD channel and back. When switching back, the non-HD channels would be shifted to the left as you describe. After much back and forth with both Vizio and Time Warner (each saying its caused by the other), I stumbled across the following fix...
I went into the cable box (scientific atlanta 8300) "settings", under "display," under "output resolution." There was a list including 480i, 480p, 720p, 1080i, and "auto select." I unchecked both 480 options and left 720 and 1080 checked. Problem solved. The other "Display" menu settings are as follows: Picture Size = Stretch, Aspect Ratio = 16x9.
Hope this helps.
Mar 27, 2008 | InFocus SC-MANGRY-106H MANUAL PULL DOWN
Tuning a Channel
why did it get the highest raiting?? it doesent even say a solution
Sep 23, 2007 | Philips 30PW633R 32" TV
Philips 32PFL7332D 32 in. LCD HDTV Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
