Question about Audio Technica Audio Players & Recorders
How do you set a 9 band eq for maximum performance
How do you set a 7 band eq on a yamaha mg16/6fx mixer for maximum performance for the aew-t5400 wireless mic.
  • 682 Answers
Start by all slider in middle position and adjust your 1k and 5k while you are speaking in mic untill you get better sound quality the other slider will be adjusted due to speaker sound type.
Posted on Dec 04, 2009
How do I hook an EQ to my yamaha m65 amp?
your eq should either come between the outputs of your mixer and the inputs of your amp, or you can connect your source (guitar, keyboard, microphone) into the eq and out into either a mixer or straight to the amp
Feb 09, 2014 | Yamaha Audio Players & Recorders
Need wire diagram for pioneer eq-6500
Pioneer EQ-6500 9-Band Car Equalizer .i want to buy this equaliser.i need 10 pieces ,please send me through my email febiano22@yahoo.com
Nov 24, 2010 | Pioneer EQ-6500 9-Band Car Equalizer
How to connect vmx 1000 to eq
What EQ? A 7-channel mixer might need 7 channels of EQ, no? Or are you just placing it on a stereo in/out? Follow the directions for the EQ.
May 17, 2010 | Behringer Vmx-1000 DJ Mixer 7 Channel -...
I am keyboard player and i want hook up an equalizer to the system where do i hook it up to
If you're only using the keyboard, connect the keyboard output to the EQ input, and EQ output to your amp.
If you have multiple instruments and a mixer, run mixer output to EQ input, EQ output to amp.
More info, let me know.
Charlie
Aug 29, 2009 | DBX 231 Dual Channel 31-Band Graphic Eq
Hook up an eq to a mixer
yes any EQ can be put inline of any sound producing insterment....but why?
Apr 24, 2009 | Behringer Audio Players & Recorders
Best settings on a 9 band eq for rock and r&b
Provided the rest of your system is all tuned an in proper shape, and up for the wattts, the best sound to set, starting with the low end...start with is a slightly elevated above zero (about 1/4 up from zero) then slowly gradually slope it down to 1/4 below zero in middle and then back up to 1/4 above at the high end.
The result is a gently curved V type shape.
Now, knock down the highest 2 or 3 freq bands a few clicks till they are just above zero. (1/8).
This is the curve you would shoot for with a real-time analyzer for SQ, punch and clarity.
Feb 11, 2009 | Kenwood KGC-6042A 9-Band Car Equalizer
EQ settings
This setting is a blast,I adapted it from the 10 band "perfect" itunes eq setting. don' t be shy , give it a try...
80hz = (2) or 7
220hz = (0) or 5
470hz = (-1) or 4
1khz = -(-2) or 3
2.2khz= (0) or 5
4.7khz =(2) or 7
12khz= (4) or 9
I have this on my LG tv, however if you need more oomph! to it, simply stick to the same pattern between the two sets above and move each slider up accordingly.
Sep 26, 2008 | Car Audio & Video
Bose speakers 800
I' ve just sold 2 pairs of 800's. The buyer(who once owned a music business) used an 802 controller to test them. He said that any bose eq would do the job with no problems.
Jan 01, 2008 | Yamaha Emx88s Powered PA Mixer System
Mackee PPM808M 1200 How to set the equalizer
Each channel strip has its own 3 band EQ with knobs that effect the hi, mid, and low.
The mid is centered at 2.5kHz and gives you 12dB of boost or cut in either direction, the high gives you 15dB of boost or cut from 12kHz and up, while the low gives you 15dB of boost or cut at 80kHz and below. At their mid positions these knobs are flat (no cut or boost).
The PPM808M also has two 9 band graphic EQs in the Master Output Section on the front panel, Monitor EQ and Main EQ. These two EQs are the last thing in the chain before the signal leaves the mixer on either of these line outs (monitor line out, or mixer line out).
The 'Monitor EQ' effects output to the monitor speakers on stage (and power amplifier if the 'Power Amp Routing' switch is pushed in).
The 'Main EQ' effects the signal to the main speakers (or the mixer line out).
Each of these 'Master Output' EQs has a Rumble Reduction button which when pressed in engages a low-cut filter which rolls off frequencies below 75Hz and is designed to prevent 'stage rumble' from things like footsteps on the stage being picked up by stage mics. These filters are separate from the graphic EQs and the Main Rumble Reduction switch effects only mono channels 1-6 (not stereo channels 7&8). It also has no effect on the EFX to MAIN or the TAPE IN. The Monitor Rumble Reduction switch however does effect the EFX to MON signal.
Dec 31, 2007 | Audio Players & Recorders
193 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
