Question about HP PSC 1610 All-In-One InkJet Printer
My 1610 all in one works fine; we have had it
Our home1610 all in one works fine; we have had it about four years. Lately, it sounds like it needs greasing or some household oil. It makes loud squeaky noises when printing. We use it often, almost daily.
  • 748 Answers
Hello
This printer is made of nearlt all plastic. If it's been constantly used for 4 years then I would say you got your moneies worth. You can't lubricate plastic with any success. Time to replace it.
Posted on Sep 24, 2009
I've had this pump for 1 year and its worked fine.
yes, it's probably on a GFCI circuit and it will need to be dried out and maybe sealed up good to prevent 'current leakage'
Aug 01, 2009 | Garden
HP 1610 All In One noise
since your printer is 3 yrs old ..just give it for a service and ensure its catridges and other part are dust free
Jun 30, 2009 | HP PSC 1610 All-In-One InkJet Printer
Making a loud noise when the paper is feeding.
This is what the HP website says about noises in the 1610..
Issue Unexpected noise (clicking, thumping, grinding, squealing, and so forth) from an HP all-in-one can be caused by a problem with the ink carriage or the scanner. Solution Follow the steps below in the order presented to determine the source and resolution for the noise. Step one: Checking the scanner This step applies only to products equipped with a flatbed scanner.
  1. Open the scanner cover.
  2. With the lid open, press the Start Copy button to make a copy. The scanner mechanism should move down the glass.
  3. If the scanner mechanism does not move and noise is present, contact HP. If the scanner mechanism moves without noise, continue with Step two below.
Step two: Checking for paper feed problems and carriage blocks Click here (buu03110) (in English) for more information on paper or carriage jams. Step three: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. So it sounds like it needs to be serviced which could get expensive. I've looked all over the web for you & Keep finding the same answer. Sorry I can't come up with a better solution for you.
Nov 29, 2008 | HP PSC 1610 All-In-One InkJet Printer
BMW installation
حضرة السيد ابراهيم ابو شرخ سوف نهديك هذه الرسالة عن تطور تكنولوجيا
Nov 03, 2008 | JVC KD-S6060 CD Player
No sound
مرحبا لدي مشكلة في تعريف كرت الصوت برجاء مساعدتي في حل هذة المشكلة لانة ليس لدي سيدي لتعريفه وشكرا
Sep 15, 2008 | Alesis Fusion 8HD Sound Card
Teac AG-D8900 static..
From what you have described, I am thinking that you had to replace some fuses? If so, the amplifier circuit may have a problem. Figuring out what that problem is will take some good electronic troubleshooting skills.
When the fuses got blown, how was the unit being used? Was it being played at a very loud volume?
Does the static come in all the channels and at all times or does the static happen in only one channel?
This problem of yours can have many different causes.
You seem to be very adventerous, willing to poke around in your receiver a bit, so I will help you more if you can get me answers to these few questions.
Please be aware, you can cause many more problems trying to fix these things if you are not experienced with them. There is also 120 volts of A/C voltage that can cause serious shock or even death if touched, so be careful.
There are a couple of things at a bare minimum you need to have to troubleshoot electronics.
You will need to have a multimeter, the troubleshooting will be much easier and faster. If you do not have one, the troubleshooting will go very slowly and will most likely end before finding the actual problem. The multimeter will be used to measure voltage and resistance, and it is vital to finding the problem. You will also need a soldering iron, solder, and solder wick (if you need to remove any solder).
Most of the parts that are used in these units are available at electronic parts stores on the internet. If you have a problem with the DSP board in this, you may not be able to get the parts needed and may not even be able to figure out what the problem is. They are very difficult to troubleshoot. I have been repairing car and home audio equipment for nearly 18 years and have become very proficient with them. But without having it in front of me, it will be a challenge. I am up for it, and I have a feeling you will be to.
Let me know,
Dave
Jul 26, 2008 | Teac AG-D8900 Receiver
HP 1610 - Skipping Lines when printing w/carriage return
You are lucky you can print ANYTHING! My unit has NEVER worked (3 years) due to a hardware defect of HP. I downloaded patches, cleaned/replaced cartridges, etc.
Spoke to HP last nite-Was told printer was junk-they don't carry it or any parts to fix it anymore!! I was told to replace it!
Apr 13, 2008 | HP PSC 1610 All-In-One InkJet Printer
Monitor will not start up!!
It may be a corrupt backup you are trying to install, but if there is a corrupt file you will need to borrow a genuine XP disc off a friend to repair it. You can use your own license number for the copy so your friend shouldnt be concerned with piracy. You may get the pc running by locating on the motherboard either the 3 pin JBAT1 terminal and put jumper from pins 1-2 to pins 2-3 then back to 1-2, or short both pins if you have a 'CLRCMOS', 'CLRRTC' or 'RTC' 2 pin terminals with a jumper cap. Restart pc and it should make you press F1 to set the cmos time and date and hopefully boot into windows, but if not the first paragraph will be the solution to the problem.
Apr 25, 2007 | Acer Aspire T310 PC Desktop
HP PSC 1610 All-In-One InkJet Printer Logo
60 people viewed this question
Seeker5211
Seeker5211
