There is no paper jam and no obstructopm. trys to move but cannot.
  • 1 more comment
  • bet6doll7 Sep 24, 2009
    hpC4200Photosmart
    Photo Express
    is this not correct?  where would I find anything else.
    carriage jam. no paperjam or forien objects. When I try to print the carriag tries to move but cannot.
  • 4,472 Answers
Http://www.youtube.com/watch?v=l9x6ZLIYMog
Watch this video and see if it helps you. Then we will go from there.
Thank you,
Lee
Posted on Sep 24, 2009
    President:
  • 1,462 Answers
May i have you make and the model number to provide furthur assistance.
Please leave it as comment
  • Vinod Kumar
    Vinod Kumar Sep 24, 2009
    Here is the Video stating, How to fix the carriage jam in your printer
    http://www.youtube.com/watch?v=l9x6ZLIYM...
    IF this helps you, Please give me a better rating for this solution,Please
    Else leave me comment ill help you
    RNJ VINOD KUMAR
The printer keeps saying that there is a paper jam when there is not.. Also some times when it trys to print it will jam and the page will be torn down the middle.
Check the machine carefully, sometins a small sliver of paper is caught in a critical place in the printer and will give the paper jam message. If you paper is being torn it is most likely due to an uneven feed caused by feed wheels that are slipping on one side while the other side still feeds normally. Clean all the feed wheels in the paper path with a Q tip soaked in Isopropil Alcohol. Also make sure that your paper guides are set to the correct widths.
Jan 21, 2011 | Lexmark Office Equipment & Supplies
I am having repeated paper jams in the rear door of y HP 4200. It occurs right when the paper hits the rollers to go into the outbin, and the paper stops and jams in the rear door area. I have to open...
It's been a while since I worked on a 4200. Will it print if you keep the back door open?
If yes, does it jam?
If yes, and it doesn't jam, replace the paper delivery assembly(RM1-0026-040CN)
Dec 23, 2010 | HP LaserJet 4200 Printer
On tray 3, the bottom one, it trys to grab the papaer, then says paper jam. But theres no jam.
The pickup rollers on your tray are worn out. If you pull out the tray and look at the pickup rollers they should have a rough surface and your are going to be smooth. The printer is trying to pickup the paper but can't so the printer thinks the paper is jammed. You will need to replace the rollers, a very easy thing to do. We sell the set of pickup rollers for $6.95 shipped.
Contact us at 318-447-9040 or tech@ccl-la.com if you need a set.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 21, 2009 | Lexmark Optra T614 Laser Printer
Paper Jams
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Nov 27, 2008 | HP Photosmart 2610xi All-In-One InkJet...
Screen says paper jam but i cleared it.
I would like you to click on the "DOCUMENT" below to somehow resolve your issue.
CLICK HERE ==> DOCUMENT
Please let me know if the issue still not resolve, so that i can go ahead and give you another possible solution.
Thank you so much. I remain.
adonscott
Jul 09, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Canon i470D...code 302 (paper Jam) shows up on the digital screen. There is no jam. When this happended the document printed, but while printing reversed it self(paper went backward) then went properly...
I had the same problem. I took a card stock sheet of paper. When you turn the printer on and it trys to take the paper thru, I forced it thru and had some small pieces of paper come out. I had the front open so I could see what was happening. It fixed mine, hope it helps u.
May 06, 2008 | Office Equipment & Supplies
Paper jam
Turn printer on,
Disconnected power cord on the back...
Press & hold #, 6 keys while connecting power cord, Keep holding till screen shows reset or shuts down..
Make sure the cartridge access door is closed tightly.
Nisar
Sep 24, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Feed problem
there is some dust in the paper path sensors or a small piece of paper cn be also in your copier
Sep 12, 2007 | Copystar CS-2114 Copier
20 people viewed this question
k24674
