My LCD flat screen just goes black after 1 hour of being on. Checked the cable. Changed channels. Turned it off and then on. Only will come back on after it is turned off for at least 15 minutes. Sound is still on when this happens.
  • 8,457 Answers
Ur backlight inverter video board is dead or dying.Must be change.
Posted on Sep 24, 2009
  • 748 Answers
Hello
You have capacitors in the power supply that are going bad. Take it to a reputable repair person.
How do I fix a black screen with sound working and LED light on.
Unplug the set and let it stand for two minutes. Plug it back in and see if it works. If that doesn't work contact Philips support: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=us&userLanguage=en
Mar 14, 2015 | Philips 42PFL3704D LCD TV
My vizio is blinking back and forth from the blue no signal screen to the actual hdmi input screen which is connected to a cable box. What is going on?
Have you tried a different HDMI input? (If available.) You may be able to test the cable box of PS4 using component cables to confirm that all but the HDMI is not working. You may try pushing or holding the HDMI cables to see if you can make the problem better or worse to identify a possible flakey HDMI socket.
Jan 03, 2015 | Vizio 26 Class Edge Lit Razor LED LCD HDTV...
LG M227WDP turns black a couple of seconds
Do you have the "sleep" mode turned off on the computer?
As well, you can try different screen resolutions and refresh rate settings on the video section of your computer. That might make the connection to the TV more stable.
Nov 27, 2013 | LG M227WD-PZ LCD TV
GTVL19W17HD When I turn the TV on, I get a picture for 2-3 seconds, then the screen goes black. This is the same on all terrestrial channels, cable and DVD. Sound is OK. I have turned everything off and...
the reason that it turn off is that there are 4 flourecentlights and one might be brokenso take it apart carefully to see if that is it if not check where the wires from the light plug in and see if there are fried
Feb 05, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
Sound stays on, but no picture- goes black and stays that way.
This unit should still be under warranty and should be taken in for warranty service. Any attempt to access the interior will void the warranty. It is important that a complete description of the problem like you entered here be taken along when you bring the set in for service. This will insure that the servicer be able to reproduce the problem and resolve it.
From your description (and as a servicer), I would be looking for a component that is heat sensitive. These types of problems are fairly easy to locate and resolve.
Please take this in for warranty service and update this when you find out the details.
Thanks,
Dan
May 04, 2010 | JVC LT-26C31 26 in. LCD Television
Tv does not stay on, screen goes black
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
Jan 23, 2010 | Westinghouse SK-32H240S Television
Screen is frozen and displaying," this is an encrypted channel." I unplugged it for a few hours, turned off and on....what do I do next
hook up your sat/cable box and reset the tuner; place the set into "setup" then: "add channels" the tuner will look for and install active channels
Apr 25, 2009 | iLO 3200 32 in. LCD Television
My over the air channel list program times are 1 hour behind.
I've just sorted the problem on my set , Samsung UE40S6300UXXU, L.E.D.
Enter, "menu"/system//time/clock/......make sure "clock mode" is set to "Auto" and scroll down to "Time Zone" make sure time zone is set to manual, go down to "GMT" and set it to GMT+1 and the job is done. Hope this helps
Mar 14, 2009 | Samsung LN46A630 LCD TV
My samsung TV won't show any picture/sound.
When the TV is on, need to check the back light is on(go back side & look into through)
If the back light is on -- need to exchange the Main Board
no back light -- exchange the Power Board --- 95%
exchange the LCD panel --- 5%(inverter)
Jan 31, 2009 | Televison & Video
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
Electro Med Services...
